Steering Rack: Active or Non Active
Old 05-20-2018, 07:54 PM
klebmw's Avatar
My Ride: BMW 525i
Default Steering Rack: Active or Non Active
Hi everyone -
I am new in the forum. My E60 2004 525i production date 03/23/2004 steering rack is acting up and i am about to replace steering rack. However, i am not sure my 2004 525i steering rack came with Active or non Active. I have check in realOEM.com but it shows both Active and Non Active Box with VIN Number.
Any help?
Thank you!
Old 05-21-2018, 05:12 AM
jtbgonesailing's Avatar
My Ride: e60 530i e21 320i
Model Year: 2005 1981
Engine: M54 M10
Start your car and turn the steering wheel left to right stops. If less than 2 full turns, lock to lock, you have active steering. If 2 or more turns, lock to lock, you don't have active steering.
Use a Vin decoder to see build list as fitted when car rolled off assembly line.
https://www.bmwvin.com
Old 05-21-2018, 10:01 AM
klebmw's Avatar
My Ride: BMW 525i
Turn engine on, turn steering wheel to right until lock it 1 and 1/2 full turn, same with turning steering wheel to left. I have Active steering rack?
Old 05-21-2018, 12:50 PM
Engine: M54 M10
On rereading your post above, if you have more than 2 turns of the steering wheel from full lock in one direction to full lock in opposite direction, you do not have active steering. In this case you indicate 3 turns for full lock to full lock.
You can also confirm your options with the vin decoder posted above.
A little something to review on active steering...
http://www.bimmerfest.com/forums/att...2&d=1526135469
oldschool_94
12-28-2011 01:07 PM
jetblack3s
12-27-2011 11:14 PM
nisonger212
06-10-2007 10:50 AM
Ziering545I
07-17-2005 09:52 AM
willbedone
09-08-2004 12:21 PM
Quick Reply: Steering Rack: Active or Non Active
