Active Steering and Active Roll Control Fault
Old Jul 17, 2005 | 08:00 AM
Ziering545I's Avatar
This error comes on when I start in the morning, the dealer recently replaced the steering rack and column.
The fault comes on and the active steering and stabalizers dont seem to work.
I drive for 1 hour shut it down and start it up and the fault is gone?
What can be causing this?
Am I taking a risk by driving to get stuck?
Old Jul 17, 2005 | 09:52 AM
Bubblehead's Avatar
I had this same error on my 2005 - make sure you have them check the hydraulic fluid level. Mine was right at the sensor level so when it was cold, I got the warning. They added a little bit but in two weeks I got the warning again. Probably had a small leak. I believe it is a real problem - take it in and make them fix it.
shervinj
May 8, 2015 09:03 PM
TexaZ3
May 6, 2015 09:54 AM
Don Juan
Feb 25, 2004 09:25 AM
Jun 17, 2003 09:38 PM
