Fix your trunk (boot) is opening too fast (part2) for 15US
Old 12-01-2016, 06:52 AM
frchdragon's Avatar
My Ride: 05 530i
Default Fix your trunk (boot) is opening too fast (part2) for 15US
Original thread: https://5series.net/forums/e60-discu...o-fast-120799/
BMW shock part number:
Trunk shocks: 7141490 - 51247141490
For those that are interested - the strut is;
Brand: STABILUS
Model: STAB-O-SHOC
Part Number:6255SA
Original repair Russian website with Hyundai shock: https://www.drive2.ru/l/6233761/
I found an alternative to trying to find the STABILUS 6255SA.
A Russian website said to use a Santa fee 2002: Hyundai 8717026011 tailgate shock. (the beauty is that you have to remove the end caps of the BMW shock and put them back into the Hyundai one)
I bought one, tried it and it was better but the trunk lid still slapped at the end.
Ok, so I realized that there wasn't enough force to hold it and I started to find the stats of all shocks with compatible stroke and length.
I found the STRONGARM 4514 worked perfectly. Only drawback is that the end of the shock aren't threaded so you need to grab a M6x1 die and thread them yourself, really easy.
Once this is done, you remove the spring from the old one (best solution is to pin down one end and have a helper hold the other end with a screw driver while you are pulling the shock off the fitting)
Once you thread the old BMW end ring to the new shock, you only have to fight it to install the spring.
A small adjustment to the left spring and the trunk now opens like new :-)
This is the picture of all 3 shocks, from left to right
New Armstrong with the spring and end caps installed
Hyundai Monroe replacement
Original BMW one leaking and dead.
This is the spring setting on the left side so the trunk can open all the way and not 3/4 of the way up.
Best thing is the cost of the repair: 15US and a bit of knuckle skin.
Old 12-01-2016, 04:04 PM
cmyachtie's Avatar
Pls provide your source for STRONGARM 4514
Thx
Old 12-01-2016, 11:42 PM
richie281vn's Avatar
My Ride: 2006 525i
Model Year: 206
Nice find. I'll buy the Strongarm off Amazon tonight. Its about 17 bucks there including delivery
Old 12-02-2016, 04:55 AM
frchdragon's Avatar
My Ride: 05 530i
Thx
You can buy it from amazon, I bought mine off ebay for 14.00: Strongarm 4514 Lift Support | eBay
The toughest part is compressing the spring and removing it.
I had one end of the shock pined down and a helper with a screwdriver on the other end holding the strut so it doesn't move. With gloves, I grabbed the spring and pulled it over the strut. Not easy the 1st time, much easier the second when I knew what to expect.
Old 12-02-2016, 04:49 PM
cmyachtie's Avatar
OK thanks frchdragon, I tried both Amazon and eBay neither ship to Canada and their .ca sites don't carry it.
However JIC someone is interested, I have done this some time ago also a good fix !
Hack for Trunk Opening Hard and Fast - Save $$!! - Bimmerfest - BMW Forums
Old 12-07-2016, 06:10 AM
frchdragon's Avatar
My Ride: 05 530i
cmyachtie, this is a cool addition to the fix. I would have done it if I had found the information.
I am lucky that my US mother company ships every week to our office in Canada so I can order from amazon.com
Old 12-08-2016, 12:17 AM
SpeedUnlimit's Avatar
My Ride: e60
good job. Just realized I have the same issue but got so used to it that I do not event notice it anymore...
Old 12-26-2016, 07:19 PM
wtlb's Avatar
My Ride: 2008 AW N52 with sports package & premium package; natural brown interior MODs: Orion V2s 3000K H8 Yellow Fogs Matte Black Kidney Grills 20" Miro 111 Hankook V12 Tires H&R Sport Springs Special coding via Simon (dbl flash hazards, digital velocity, etc.) LED Side Markers from Trinity Autosports LED License Plate Lights from Trinity Autosports Carbon Delete BMC Air Filter RPI Scoop RPI GT Exhaust Future MODs: Mtech Kit KW Variant 2 Coilovers CIC Retrofit Upgrade Audio System
Great work
Old 02-27-2017, 07:08 PM
My Ride: 2006 525i
Model Year: 206
I replaced the strut with strongarm but then the trunk only open half way up. If i lift it up myself then it still falls down halfway which is very inconvenient. Any idea to fix this?
Old 02-28-2017, 02:35 AM
cmyachtie's Avatar
Did you try to adjust spring on the other side to increase the tension?
