FS: E60 OEM amp PnP trunk subwoofer harness with built in LOC
My Ride: M3
Model Year: 2017
As a quick and efficient solution for those that would like to either add a trunk sub or replace the OEM woofers with SWS-8 (with harness modifications), this is a custom made to order, plug 'n play complete harness with a built in, either 50W or 150W max Navone LOC -depending on your OEM audio system- with remote turn on signal output right at the harness itself -no need to run a remote wire from the cabin.
This harness connects between the OEM amp and the OEM audio connector using OEM connectors, so no OEM wires need to be cut, spliced or tapped. Just plug it and add the amp. Navone LOC takes care of the Top HiFi (Individual Audio, Logic7) and the standard HiFi OEM amp high power woofer outputs, so interface with any aftermarket amp is guaranteed.
Applies to the E60 5-Series and 6-Series. Can be used with the Top HiFi (Individual Audio, Logic7 or HK Premium systems) of the 1- and 3-Series. PM for details.
Price: $75 for 10 members (PayPal when list is full), shipped in the USA, 1 year warranty in case of defects or malfunctions. Warranty void if harness is modified in any way.
1.TEAM M
2.god_003
3.allenzo
4.
5.
6.
7.
8.
9.
10.
1.TEAM M
2.god_003
3.allenzo
4.
5.
6.
7.
8.
9.
10.
My Ride: M3
Model Year: 2017
My Ride: E61 535d carbon black m-kit panoramaroof with beige nasca interior and wood trim. 172m rims. DimSport Race, SB, SAT
If you have no amp in the first place, I take it it wont work at all, right?
My Ride: M3
Model Year: 2017
would that run from the HU to the trunk, to connect to the amp, so that any feed from the amp subsequently goes via existing wires to the subs under the seat, or would it simply give remote on/off from the HU as well as low power input to the amp, and I'd still have to run seperate wires to feed the subs and bypass the stock wires?
My Ride: M3
Model Year: 2017
One extension cable (9-wires) takes the front and rear outputs of the iDrive unit and extend those to the trunk, including the OEM remote signal. The other extension cable (8-wires) is used for the aftermarket amp outputs to be connected from the trunk to the back of the iDrive (speaker inputs).
If your idea is just to power the underseat woofers only then what you could do is to interface the woofer connector right at the OEM woofer enclosures, like I posted before. Try to get an amplifier that can accept at least 8V high level inputs, so you do not need to add any converter, just connect the woofer wires directly to the amp and then the amp outputs to the woofers. A signal sensing amp can greatly help you with this install, something like the Blaupunkt PnP amps (I think that they are discontinued, though).
