What are the best settings to use when burning a MP3 CD?
#102
Originally Posted by russdx' post='823653' date='Mar 22 2009, 09:37 AM
free mp3 upgrade doesn't even apply to the uk
#103
Hey guys,
just got my car back from the dealer.
so here is the story, my car is 06 525i, production date Jan 1st, 2006, it cannot play mp3 disc.
and i read this thread from fellow e60er that car can be re-programmed to have it play mp3 disc under warranty, i took the print-out sheet to the dealer, but the dealer refuse to do it for free, because it says it will only cover e60 5s up until 09/2005, so my car doesn't qualify. Fine, I said go ahead I will pay for the re-program.
Then few hours after I left dealer, the dealer called me said when they try to re-code/update the headunit, it yields error code, so they are gonna replace the headunit under warranty. I was like: sweet.
Then now it's the funny part, the dealer SA called me again today said that BMW Canada refused to warranty, because mp3 is not supported until March 06, so basically they cannot replace the headunit under warranty nor be able to re-program it.....
I think it doesnt make sense logically, e60s up until September 05 can have software upgrade to play mp3 ( which is older than my car), and car after March/06 have mp3 ability out of factory. So cars from Spet 2005 to March 2006 can neither get a software upgrade nor a replacement headunit...
does anyone else sense bullshit here??
Help would be greatly appreciated!
#104
My Ride: 2008 530d M sport
Tell Them that you want the headunit replaced under warranty AND also want the latest software upgrade (as this will be required anyway for the headunit)
Its not the headunit that plays the software, its the idrive software capability. Thats why it needs to be version 20 or above. the SIB bulletin states Start of production to sept 05. Cars built after that should have the latest sofware that plays mp3s anyway.
The link will prove that your stereo and that your car is MP3 compatible. It should all be able to be done under warranty.
Print this SIB out - This SIB states that it can be done from SOP (start of productions, which was 2003) so they should do it for you and there is a deffect code on there.
You must have produced the SIB from Jan 2006. This one below is from March 2006 and is therelevant one.
http://forums.e60.net/index.php?act=attach...st&id=92282
It shows that a software upgrade would enabkle the MP3s to be played. I have just had this done on my 530i M sport in UK
This Service Information bulletin supersedes S.I. B65 30 05 dated January 2006.
designates changes to this revision
SUBJECT
CCC: MP3 CD Playback Not Available
MODEL
E60, E61 (5 Series) with SA 609 CCC-Navigation from SOP to 9/29/05 vehicle production
E63, E64 (6 Series) from SOP to 9/29/05 vehicle production
E90, E91 (3 Series) with SA 609 CCC-Navigation vehicles produced up to 9/29/05
SITUATION
The MP3 option is not available in the audio menu. When an MP3 CD is used, it is not recognized as a valid CD.
CAUSE
The stability of earlier CCC (Car Communication Computer) software did not allow for proper MP3 functionality.
PROCEDURE
1. On a customer complaint basis only, retrofit MP3 functionality using Progman V20.00 or higher.
2. Refer to the SI B09 05 01 Coding, Individualization, Programming (CIP), for the "Retrofit" procedure.
3. Select "MP3" from the retrofit list and follow the on screen instructions for retrofitting MP3 capability.
4. The service code "KMP3" will be added to the end of the vehicle order as displayed in the Measures Plan.
5. After the procedure is complete, turn the ignition off and wait 5 minutes or until the driver's switch block LED
goes out. Check the functionality of the system.
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
SI B65 30 05
Sound System, Cruise, Alarms, Monitors
March 2006
Technical Service
Defect Code 65 83 94 23 00
Labor Operation: Retrofit MP3 (programming/coding
performed as part of a Technical
Campaign)
Labor Operation Labor Allowance
+00 56 743 4 FRU (E60, E61, E91)
3 FRU (M5, E63, E64, E90)
Page 1 of 2
http://www.bmwtis.com/tsb/bulletins/bullet...mp/B653005g.htm 12/22/2006
Note: Should the vehicle be affected at the same time by another repair in which programming of control units
is also required, programming may be claimed only once.
Note: The following explanations will spell out the correct use of the work times.
00 56 110 10 FRU (E60, E61, E91)
9 FRU (M5, E63, E64, E90)
+00 56 744 8 FRU (E60, E61, E91)
7 FRU (M5, E63, E64, E90)
Labor Operation: Retrofit MP3 and program/code control
modules
00 56 111 16 FRU (E60, E61, E91)
15 FRU (M5, E63, E64, E90)
+00 56 745 15 FRU (E60, E61, E91)
14 FRU (M5, E63, E64, E90)
modules (including CAS)
00 56 112 17 FRU (E60, E61, E91)
16 FRU (M5, E63, E64, E90)
+00 56 746 16 FRU (E60, E61, E91)
Main Work: Use this labor operation number when the only repair performed is the
listed warranty repair.
OR
+Associated
Work:
Use this labor operation number when other repairs or services are
performed along with the listed warranty repair.
Under no circumstances should both labor operation numbers be claimed.
Attempts to claim both times will result in an unnecessary delay in claim
processing and payment.
[ Copyright ? 2006 BMW of North America, LLC ]
Page 2 of 2
SUBJECT
MODEL
SITUATION
CAUSE
PROCEDURE
SI B65 30 05
March 2006
Technical Service
Campaign)
Page 1 of 2
modules
OR
+Associated
Work:
Page 2 of 2
#105
Just used this.....
got 530 i Msport with pro nav
#106
My Ride: E61 525D M Sport, Carbon Black, Black Dakota Leather
Sorry to ressurect this, but I would like to get the MP3 recode before buying a dension gateway 500, I printed the info out and am awaiting a return call from Sytner Coventry. Exactly how did you approach the subject with the dealer to get it doen on extended warranty?
thanks
thanks
#107
thanks
thanks
But not sure how it works on the extended warranty.
#108
My Ride: 2007 530i, Sapphire Black with White trim. M-Sports package
#109
My Ride: M Sport 530d fully loaded with 19inch wheels 2006 Pro Nav
My Car is strange, I had a software update and my CD player will not play mp3 but my DVD player plays everything I throw at it MP3, CDs except DVD Movies, I guess if I have a mp3 video it will play it.
Any Idea what is wrong with my CD player?
My CD player will not play CDs either but the BMW Specialist that did the software update for me said there is nothing wrong with my CD player
I get "NO SUPPORTED AND READABLE AUDIO MEDIUM FOUND IN THE INTERNAL DRIVE"
