11 535i xDrive cranks but don't start
My Ride: 2011 535 ix
Hi, new member coming in with problems with my 2011 535 ix. Hope to find some guidance. Thanks
problem #1 car was working fine then just died can’t restart. Turns ove but won’t fire . Only code is for tpms malfunction
help.
help.
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Have you tested your battery? Where you working on the car before it stopped starting?
No I wasn’t working on the car and I keep the battery, which is less than six months old on a trickle charger from the jump points under the hood
Yes it seemed to be running fine and I was probably going about 50 mph when it died. When I try to start it it feels like it wants to start but then just continues to turn over. I’m going with the old adage a car needs fuel and spark. So need advice on best way to check this. Thanks everyone for responding
Model Year: 05 530i
Engine: 3.0 M54
If it went while driving to me that would seem like a crank position sensor or cam position sensor issue. I don't want to speak the worst scenario which is the timing chain but that should of given you multiple codes. Look at your sensors to see if the are oily or connector wires are damaged. I would go as far as ohming it out to check to see if they are good. Start with crank first. I had mine go out and had no codes at first but when I checked the sensor it was covered with oil. Swapped it out and it's been fine every since. You may need a better OBD reader also. There is definitely codes you're not seeing with what was used.
Thanks , I went into he car computer that shows up on the speedo cluster and don’t have any code except for the tpms. I doubt , fingers crossed , that it’s a timing chain issue as there was no cel showing when it stopped. I’ll check the crank position sensor. That’s a good suggestion. Thanks again
