What batteries fit in this thing?
My Ride: BMW 535xi Touring 6MT
Hi folks,
I might need to replace a questionable battery in a new-to-me 2008 535xiT 6MT. My searches tell me the following:
The battery in the car now is an Autocraft FLA H8. However, there is a 5/8" block of wood under the hold-down bracket, there are loose connectors (IBS?) hanging about, I don't see any vent lines, and I can see daylight through a hole in the compartment floor:
IMG_20170426_104707 - Imgur
IMG_20170426_104723 - Imgur
Being new to these cars, I don't know what is correct or incorrect.
I've read about brackets with multiple installation positions for multiple sizes, but I only see the two holes the bracket is currently mounted with. I don't see a BMW part number on the block of wood, so I'm not sure what to make of that. Where does the other end of the vent hose go? Is it missing completely?
I'm getting both unresettable/ghosted TPM faults (all sensors tested good) and High Rate of Battery Discharge faults. The next step is to replace the battery with an AGM. But because of this block of wood, I don't know what to order.
Was there a factory spacer under this bracket? Was something taller than an H8 installed in the E61 cars? I can't order until I know what I should order. Help!!
- These cars can use a variety of sizes (H7, H8, etc.).
- These cars can use both FLA or AGM batteries.
- Registration is recommended after battery replacement, and required when changing specs.
So I've found that the E61 battery layout is indeed different than the E60, and I found a great E61 writeup with pictures here:
https://5series.net/forums/diy-do-yo...attery-102420/
This picture references a cargo tray held in by three screws:
https://5series.net/forums/diy-do-yo.../#&gid=1&pid=3
But in my car, it looks like this cargo tray was sawzalled out:
46c2M43 - Imgur
I am not sure what to make of this. Is there a plastic tray that the battery is supposed to sit on, and that's why my H8 battery is too low? My battery is just sitting on the metal floor of the chassis.
I am also missing the battery clamp shown in the other guy's writeup; I just have empty space and a hole in the floor...
Ugh.
46c2M43 - Imgur
Ugh.
My Ride: E61 525i 2005, F11 528i 2012
Model Year: 2012
Certainly, a piece of wood does not belong there.
I would slowly bring this part of the car to its original condition.
Here is a link where the construction is described along with the parts.
RealOEM.com - Online BMW Parts Catalog
Check what you need.
My Ride: white
Model Year: 1947
Engine: b38
46c2M43 - Imgur
46c2M43 - Imgur
There was no tray at the bottom of the battery well on my wagon, just painted metal with a patch of panel deadener. This is my post on my battery replacement experience.
