Transmission needs to be reset after not driving
My Ride: E61 2009 touring
Hello, so my transmission adaptation needs to be reset every time after about 24 hours, if not driven.
If it is not reset, the car will not move unless I give it max torque, then it moves slowly, a little and everyone wakes up.
After a while of driving (in max torque because it stays in first gear and barely moves) it finally begins to work normally and change gears.
And if I've driven with it a couple hours ago and try again, it works normally right away.
But resetting the transmission adaptation makes it work normal and fine right away,otherwise it really doesn't even move at all.
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Sounds to me like your fluid wasn't filled back up properly and it's low if you have to keep resetting adaptions which is not good for the transmission. Just guessing without codes.
Makkaraaa (09-23-2024)
aresh
04-20-2009 07:50 AM
