Trailer Electric Module Defection Coding Delete
Does the trailer module not control the output for the trailer lights? I'm concerned that removing $235 will also prevent any trailer wiring from getting a signal if they come from that same module. If you just want the error to be gone, but still use the trailer module I think you'll need to scan with INPA/ISTA/other tools to see what exactly the error is and then troubleshoot it.
My Ride: BMW 525d E61
I have searched yesterday through INPA and I will search tomorrow too, what's wrong with the module, maybe because I changed the DPF Module? Anyways I just want the error to disappear because it's really annoying when I go to work and I see that thing in my dashboard. Hope $235 will be the Saint
@kd7iwp Out of curiosity, what are some of the things you've coded on your car? I'm working my way through activating my rear cargo roll up cover, so I'm figuring out how to use NCS Expert. Have gotten to the point of reading all the modules in the car, without making any changes yet. Would be interested to know what some other E61 owners have coded.
I am looking forward into coding so the mirrors would fold when I lock the car, when having high speed, the doors should lock, the dashboard rpm and kmh to go clockwise when turning on the engine and much more, but now I have coded so no errors would appear
on an individual module level I did things like showing active backrest and seat heating/ventilation levels on the CIC display, fog lights on with high beams, variable light distribution with the headlights, current fan speed displayed while in auto mode, and other random little goodies.
Does this mean you had success getting rid of your "Anhangerelektrik ausgefallen"?
Wiring is handled by the AHM module, though I'm not sure which module controls the electric drawbar (I vaguely remember AHV maybe). They might be the same and the difference is controlled by a different VO. You should be able to code out the errors similar to coding out the hot/cold monitoring of the bulbs.
Cheers,
Andy
ex-07 530iT 6MT
15 M235i 6MT
17 S1000R
notoriousg
05-13-2020 10:07 AM
