Touring rear suspension failures
Old 05-22-2013, 02:48 AM
  #251
Nimesis's Avatar
My Ride: Plucked bmw.....
Can someone please tell me, where the suspension compressor on E61 M5 is located?
I Googled for some pic., but didn't find any.
In case if I will upgrade to the M5 exhausts.
Tnx.
Old 05-26-2013, 03:49 AM
  #252
xarly_cye's Avatar
My Ride: Bmw 530dA Touring
Hi from Spain.
I have a problem with the rear suspension of my 2004 530d e61.
The car doesn't indicate any error in the i-drive, but is very low in the rear. As if the compressor doesn't have the strength to command the air and lift the car. Because the car didn't make mistake, I don't know what is the failure of the suspension.
The air springs were changed three months ago by the previous owner, and the pipes that connect the air springs with the compressor were also changed.
Can anyone help me?
Sorry for the bad english
Thanks!
Old 05-27-2013, 11:10 PM
  #253
tom_il's Avatar
My Ride: BMW 525dA 2007 pre-LCI.
Originally Posted by xarly_cye
Hi from Spain.
Can anyone help me?
Thanks!
Your compressor is gone.
Old 06-01-2013, 08:06 AM
  #254
KAF
KAF's Avatar
Model Year: 2015
Engine: N55
Just had my compressor replaced.
Been having warnings for several months, the warning came on, at start up, a couple of weeks ago the warning came on but stayed on the whole time, didn't revert to a background '!' type warning.
During the drive it was apparent that something major had happened, the rear of the car was almost on the floor and every minor road surface imperfection was like driving over a kerb!
New compressor was needed, total cost £1063.20 !
Luckily I have an after-market warranty that paid 60% of the cost of the parts, all the labour and the recovery change.
Old 07-13-2013, 08:20 AM
  #255
psg
psg's Avatar
My Ride: 535XiT
Originally Posted by psg
FWIW, I recently had a transfer case servo motor actuator relaced ,due to a 4x4 failure warning, and the vehicle software was updated to the latest version. I was having the rear self leveling suspension failure indication on 90% of the time, even thought it seemed to be working ok. Now the warning is seldom on, to the point where I won't bother changing the pump etc like I was planning on before. Early production 2006 535XiT, 188,000km.
Stu
update: 208,000 km, leveling failure warning still only comes on infrequently.
Old 07-29-2013, 09:49 AM
  #256
hosburger's Avatar
My Ride: 525d touring
Default Compressor blowig from inlet
Hi,
Bit of a weird one but my compressor actually is blowing from the inlet. I take it this is just a blown seal and not some weird electrical fault ? I am getting the common fault message and comp is running but there is no change in ride height.
Also . Can anyone point me in the direction of a good write up on how to change the compressor ?
Cheers
Old 07-29-2013, 04:39 PM
  #257
Deb6orah's Avatar
My Ride: FGH
I think BMW does this to save time, time is money for them, you know.
Old 10-11-2013, 10:10 AM
  #258
customclothiers's Avatar
My Ride: 2006 BMW 530xi
where is the relay located for the compressor?
Old 10-11-2013, 01:16 PM
  #259
Tiago's Avatar
My Ride: 535d
Model Year: E61 2006
Inside the car and below the trunk floor.
Old 04-07-2014, 01:04 PM
  #260
UrbanTiger's Avatar
My Ride: 2005 525i M-style Carbon Black with almost
Model Year: 2005
The problem with the compressor is that when the hose is broken it sucks in dirt and grit that causes the piston rings to wear out. Especially the small end is important bacause it is the high pressure side. If the ring is worn the pump will work for long time without getting enouh pressure. If the ring breaks completly the mump will blow air from the inlet.
Repairing of the compressor can be done by replacing the plastic piston ring for the small side piston inside. The replacement part is a 3mm o-ring with inner diameter 22mm together with lubricating all with a little grease.
Operation as follows.
With compressor of the car remove the bracket with three screws.
Remove the cap srew, loock inside and see the motor shaft.
Remove the two long screws holding the motor to the compressor house.
Secure the back end lid on the motor to the motor house. If it separates it can cause damade to the bruches. Use duct tape to do this.
Now drive out the motor shaft by using a mandrel and a hammer. This is the tricky part. My shaft refused to come out from the bearing an de bearing came out of the piston instead. So i had to enladge the bearing seat a bit to be able to reassemble it later.
Now with the motor off open the piston chamber lid with the four screws.
Clean everything, replace the small end piston ring with the o-ring.
The sliding band bearings and the big end piston ring can probably be left as is.
Small amount of grease on the parts an reassembly everything. Important to get the motor shaft and the bearing in the right position.
Good luck.
Quick Reply: Touring rear suspension failures
