Touring rear suspension failures
Old 02-28-2012, 10:20 AM
  #221
1Animal1's Avatar
My Ride: 535D Tourer - Pre LCI
Although I feel im talking to myself....
It's fixed!! the specialists i took it to, to sort my Idrive sorted this too - turned out to be the relay
Relief? oh yeah!!
Old 02-28-2012, 12:37 PM
  #222
mmitev's Avatar
Relief? oh yeah!!
Hmm.. did he replace the relay? Or why does he think it was the relay? If the compressor sums for 30 sec, then I would say the relay works as intended?
Usually the problem with the compressor appears and disappears for some time for no apparent reason, before it finally hits you and the rear remains sitting on the bumpstops. So I would be glad if the relay was the real problem, but I would not count on it just yet.
Old 02-28-2012, 12:49 PM
  #223
1Animal1's Avatar
Ah, in that case i'll keep an eye on it....
He replaced the relay, i replaced the inlet pipe last week - after i changed the pipe, i only got the compressor to run once or twice (i was hoping the pipe fix was the problem)by putting weight in the boot.
Old 02-29-2012, 01:27 AM
  #224
Tiago's Avatar
My Ride: 535d
Model Year: E61 2006
+1
The replay function is to avoid the compressor to work permanently when there is air leaks on the pipes or when the compressor is damaged and takes longer to levelling the suspension. If it shuts the compressor after 30sec, then the relay is fully operational.
Old 02-29-2012, 03:40 AM
  #225
1Animal1's Avatar
Originally Posted by Tiago
+1
Hmmm, Is it possible to see the suspension rising upon putting weight in the back? I think some testing is in order....
Old 02-29-2012, 01:11 PM
  #226
mmitev's Avatar
yes its possible, but there's no point in testing it.
it may work ok today, fail tomorrow, and then run ok again the week after.
you can continue to use the car and if the problem occurs more often, just start searching for a cheap suspension compressor, so that you have it handy when you definitely need it.
Old 02-29-2012, 11:47 PM
  #227
1Animal1's Avatar
Thanks MMitev - I jumped in the back last night and it made the usual noise, i think it lifted to a certain degree... but the warning light came back on the dash? Therefore I shall be taking your advice
Old 03-01-2012, 01:53 PM
  #228
1Animal1's Avatar
I've found a unit, reconditioned! but it has no frame with the solonoids attached...do you think its worth checking mine first before buying a whole compressor?
Old 03-01-2012, 10:11 PM
  #229
mmitev's Avatar
First time I hear of a "reconditioned" unit. Not sure this will be reliable, unless whoever did it knows exactly what he was doing.. But I changed mine in Oct 2009, in the meantime someone might have learned how to repair them.
Checking yours: The only thing you can check is the pressure it generates. If its much lower than intended, its broken. A BMW dealer once told me the factory pressure was 15 atm., and mine was generating 1 atm.
Old 03-02-2012, 12:04 AM
  #230
1Animal1's Avatar
Well its going back to the specialists to have a new light module coded (Halo's not working ) so i'll ask them to have another look at it.... I'm still in two minds as to whether i should buy this unit for £200 - seeing as i can get a full new unit off ebay complete with brackets and solonoids - my thinking with that is that i will be able to change it myself and i'll likely cure the issue.
As its level at the back now i think i can rule out the air bags, also relays changed....the only things im thinking now are the controller, solonoids or compresssor
Quick Reply: Touring rear suspension failures
