Possibly BAD battery??
Old 03-15-2021, 01:11 PM
  #71
pavjayt's Avatar
My Ride: E61
Model Year: 2009
Engine: N54
your mode should be base in easy connect. Don't worry about the above post for now
Will try this today Sean, I was always under the impression that Base mode is for communication via OBD which is a BIG no for updating peripherals on MOST bus. Probably I am misinformed.
Old 03-22-2021, 07:16 PM
  #72
pavjayt's Avatar
My Ride: E61
Model Year: 2009
Engine: N54
I spent sometime again today to get my ICOM-B being recognized with no luck.
As Sean suggested, tried setting EasyConnect to REMOTE:Base and locked ICOM, but as soon as I load PABD and P-SGBD, it spits out error below
So, I swtiched it to REMOTE:MOST_ASYNC_ab625 and locked ICOM and again the below error shows up as soon as I enter ECU address 63
Here is the software version of my CIC as read by EasyConnect
I mean this is not rocket science, I am sure there must be something simple that I have been missing all this time. If someone can just help me out in connecting successfully and communicate via ICOM-B, thats all I need. I have all the required tools, both hardware and software and I have done quite a bit of normal coding barring Most bus. Just missing hands on experience using these software tools. I am still being optimistic that this can be resolved.
Old 03-23-2021, 04:57 AM
  #73
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Did you add the variable path correctly into windows? Did you import the daten file correctly.
Old 03-23-2021, 05:06 AM
  #74
pavjayt's Avatar
My Ride: E61
Model Year: 2009
Engine: N54
Proper path is in system PATH variable as below
and my Ediabas folder is in c drive as below
I am using BMW Coding tool to update SP-Daten to V41 and then copying CIC-v41 folders into NFS data folder as documented here
Not sure where the issue is coming from except that my path has C:\Ediabas vs actual folder is C:\EDIABAS
Old 03-23-2021, 06:22 AM
  #75
Model Year: 05 530i
Engine: 3.0 M54
Delete files in ECU folder and add them manually from daten. It's not seeing a file correctly
Old 03-25-2021, 06:03 PM
  #76
pavjayt's Avatar
My Ride: E61
Model Year: 2009
Engine: N54
Unhappy
I just tried this again by copying the files manually following the pdf linked here. Still I am having 106 error, Setting ECU address job.
Isaiah_Charles
04-11-2011 10:19 AM
GP550iSport
04-28-2008 11:42 AM
snkpkp
04-20-2008 12:23 AM
Iceman
10-08-2007 07:41 AM
gonzo40
04-19-2004 02:44 PM
Quick Reply: Possibly BAD battery??
