Lowering a e61 question
My Ride: 550i
I lowered my E61 with the ICS coilovers and a light with a car on lifts showed up on my dash. anyone know how to remove it? is this common?
I'm guessing that's your rear air suspension telling you things are uneven in the rear. The system is designed to auto-level, if it doesn't there may be an issue with the ride height sensors.
As far as I know the removal of the rear bags can not be coded out. Meaning you'll always have an error message if you choose to remove them.
My Ride: E61 535Xit
My suspension is stock. Had the same error message as TS and it turned out it was one of the ride height sensors on the rear that was bad.
I strongly suggest staying away from the ISC suspension for a bunch of reasons that I am not going in to detail about in this thread.
yiqiuc
21
08-05-2016 11:22 AM
xiTouring
01-29-2016 01:17 AM
