Lowering a e61 question
I lowered my E61 with the ICS coilovers and a light with a car on lifts showed up on my dash. anyone know how to remove it? is this common?
I'm guessing that's your rear air suspension telling you things are uneven in the rear. The system is designed to auto-level, if it doesn't there may be an issue with the ride height sensors.
Originally Posted by bmwmonkey
(Post 1577379)
Originally Posted by Mrmandmman
(Post 1577417)
Did you remove the rear air suspension? I think you need to do some coding if you did.
As far as I know the removal of the rear bags can not be coded out. Meaning you'll always have an error message if you choose to remove them. |
(Post 1577420)
My suspension is stock. Had the same error message as TS and it turned out it was one of the ride height sensors on the rear that was bad.
As far as I know the removal of the rear bags can not be coded out. Meaning you'll always have an error message if you choose to remove them. I strongly suggest staying away from the ISC suspension for a bunch of reasons that I am not going in to detail about in this thread. |
RCB. I have the ICS suspension myself and im not happy. makes alot of "Noise"
do you know how the airbags was coded? my independent shop was clueless |
