Keyless entry troubleshooting
Old May 21, 2018 | 04:02 PM
driftxsequence's Avatar
My Ride: 535XIT
Default Keyless entry troubleshooting
We recently picked up a wagon and purchased it knowing the keyless entry was no good. It's now my job to figure out why and get it working for the Misses.
I started off by replacing the key fob battery and that resulted in no change. Now today, I replaced the diversity antenna as well with no change.
There was a previous hatch wiring repair that doesn't look to good....I'm going to repair that soon as well.
Besides that am I missing anything? Any way to test the fob or car? What fuses should I be checking?
Also...I accidentally broke the ribbon cable for the red plug...any one have an idea what that is? It sheared off and I can't see where it's supposed to go.
Old May 21, 2018 | 05:31 PM
My Ride: 535XIT
Small update. keyless DOES work. range is short, the button press doenst always result in an action. I ordered a proper VL2020 battery as I rigged a CR2032 in there currently. Will test more tomorrow....
Old May 28, 2018 | 06:55 AM
Chris_B's Avatar
My Ride: 530i touring, N53, manual, PDC, DAB etc
I think the red ribbon should go down into the glass. The black ribbon goes up into the spoiler.
Neither of my fobs worked when I got the car, but a locksmith showed me they were both emitting signal.
Ultimately, I had to replace all the bodged loom wiring into the glass, including sorting the switch, and finding out how to ping the lid with no power, and then I found that the diversity antenna was knackered, and I replaced it.
Everything is now working properly. However - my red ribbon cable was OK.
Old Feb 23, 2019 | 07:10 AM
martajlloyd's Avatar
Banned
My Ride: na
That's strange locksmith service is needed for that fob issue..
Old Feb 25, 2019 | 08:25 AM
kd7iwp's Avatar
My Ride: 2009 535xi Touring 6MT, 2019 i3s
Engine: N54
I have the same issue with mine as well. I don't want to drop $400 on a new antenna amplifier if I don't know for sure if it's broken or not. I've looked at all the wires in the loom and they appear fine but I'm not opposed to replacing them if I have to. There is no sign of corrosion or water penetration on the amplifier module as some others have shown.
Old Feb 25, 2019 | 11:30 AM
dcfjord's Avatar
My Ride: 2x E61, 1x E60, 1x E90
Model Year: 07,07,10
Engine: N52, N54
This should be a good reference on which wires to trace. I had the same issue, what fixed it was the hatch wiring loom. I am now having the issues again but that is due to an imperfect job the first time.
Old Mar 9, 2019 | 05:59 AM
dennis_maine's Avatar
My Ride: 5 series wagon cold weather package premium package
Model Year: 20006
Engine: ?
I just wanted to add a comment to the diversity antenna issue, without starting yet another thread. My comment is: Be aware that there are two frequencies used on the E61: 868.4 MHz and 315 MHz. Make sure your replacement is the right one.
Old Mar 15, 2019 | 10:44 PM
norsecarnut's Avatar
My Ride: 2008 535xiT6
that's a very good post. thx. will be digging into this soon to sell the car in proper working condition.
Old Jul 8, 2019 | 07:51 AM
EasonApollo's Avatar
My Ride: na
Before selling the car, one must think about that option. It will help to fix the issue, i also took help from suffolk county locksmith for keyless entry troubleshooting problem.
Old Aug 11, 2019 | 12:31 AM
SamBilling's Avatar
My Ride: bmw
I faced troubles like locked keys in car or lost keys many times but i never thought of selling that car. With the help of mechanic i overcomed that problem but never thought of selling my car.
