ignition coil...
My Ride: E61 525Xi
Why does my ignition coil malfunctioning?
It is the 3th time that I have changed the coil...
What can be the problem?
My Ride: E61 525Xi
Sorry,
I have this problem now about a month..
My car is converted to LPG but the problem is also when I drive on gasolene.
So:
Stationair the RPM is not constant. It is moving from max 1000 rpm to almost 500Rpm. If it hits the 500 it looks like that the motor stops.
If I then start driving the car is stuttering and around the 1500RPM the engine light is coming up.
After I have checked the fault with ELM5(OBDwiz) it says everey time P306 (misfire cilinder #6)
I have replaced the ignition coil several times but the problems comes back.
What can this be? (sorry for my bad English)
So:
Wonky
04-12-2016 08:15 PM
