E61 Remote continuing Woes
I have a problem where my BMW E61 Keyfob which will only open and close the car when standing at the rear of the car. I replaced the re-chargeable battery after reading that they can fail over time. No noticeable improvement unfortunately. Reading a little more I discovered that the diversity aerial is also a problem on this particular model.
I think I may have a problem with the rear window washer which fits in with others experiences.I just didn't realise there was a connection. The question I'm asking is if the unit has failed then why would the doors still open/close? I would have thought it would not work at all.
Has anyone any ideas
Regards,
Barry
Regards,
Barry
Its a tough question to answer - it may have failed only partially, and it might also be the cables and not the diversity module - the wiper problem points in the cable harness direction..
I would suggest as a first step open up the Diversity Module and see if its damagd or not - its really a 15 min job and it will bring you ahead in the search for the culprit
My Ride: 07 E61 530d M-Sport.
When my diversity antenna failed it didnt just stop working. The distance the keyfob would work at started reducing until it just no longer worked at all.
I would suggest as a first step open up the Diversity Module and see if its damagd or not - its really a 15 min job and it will bring you ahead in the search for the culprit![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
At a glance it looked in best condition.
xiTouring
08-17-2015 07:13 AM
