E61 535i touring lpfp help!!!
My Ride: 09 535i xdrive, PP,WP,LCI
Model Year: 2009
Engine: N54
Need help!!! E61 535i wagon is reading 88psi at idle. I have to turn the car off and on a few times for it to actually go back to reading at 72.5psi. Does anyone know why this would be happening and how to fix this issue?
Engine: 3.0 B58; 3.0 M54
A lot of important info is missing. Is it causing an issue? The pressure is controlled by the DME. If it's not causing an issue then let it be. If it's bothering you then it sounds like it's time for a new pump assembly. Are you tuned or anything? Has the pump been replaced before? When did this start happening?
Model Year: 2009
Engine: N54
Model Year: 2009
Engine: N54
