Hey, sorry if this is hard to read. English is not my first language.
I bought a used E61 530, it has seen 184,000 miles. The problem im having with it is that the speed, rpm, diesel cauge and boost cauges are not working. The lights work, and the miniscreen. You can barely see the miniscreen. I got the cluster to work just by pulling one fuse out of the glovebox. It was fuse for something not related to the cluster, when i pulled the fuse out and put it back, the rpm's and speed worked. After that i turned it off, and the cluster didnt work anymore. Then i tried pulling the cluster out, removed the wire. And it started to work again, for one start.
I obd scanned the car aswell, got a code "A557 signal faulty"
I checked all the fuses, did the cluster test, same results. Checked voltages on the battery and charger. Im slowly going insane, cant figure this one out. Any help would be nice since i really cant drive this without knowing how much gas i got. this is how it works, or rather how it doesnt work
