Drivers airbag light
Hi guys, just bought my first touring 05 msport 525. The airbag light has appeared on the Idrive and dash. I've done loads of searching and it look like a visit to the dealers. Does anyone use a reset tool ? I'd rather buy one and do it myself if this is going to be a regular occurance
My Ride: 530D
Air bag light on could be a number of things but could be the seat occupancy sensor which was the common issue on the E39 also.
I don't think you can get a air bag reset tool for an E60/E61, the fault has to be switched off using a sofware interface tool.
I had an Air bag error on my car last year and turned out to be a faulty +VE battery connection, reading the code it came up as 'SBK fault' Safety Brake Konnector. This is the explosive trip which triggers when you have an accident and disconnects the battery. I had to take it to a dealer as my trusted BMW indy garage could not diagnose and repair it. Really expensive to fix, as the part was £200 alone plus the labour and VAT. Final bill was a tad over £400!
Someone else on the board here had the Air Bag fault and found their +ve terminal connector was loose, tightened it up and fault went away.
