Different VIN in car modules
Hi. Last month I have retroffited the gear ECU and shifter. I bought these parts in ebay
I have checked with the INPA and I saw that the GWS has different VIN. This is normal because it comes from other car.
I have three questions:
1.- Is there any way to change VIN from GWS and put mine?
2.- Could it be this mismatch of VIN between different parts source of problems?
3.- Why modules HKL/ZBE do not show VIN number
Right now after the retrofit I have problems with Active steering, DSC
Attached you will find the errors and the module information where you can see that GWS has a different VIN
ADR Gen. name JobStatus Number of errors Error code Kind of error 00 ZGM OKAY No Error stored
01 SIM/SGM OKAY No Error stored
02 SZL OKAY 1 Error stored A85D 68
12 DME/DDE OKAY No Error stored
16 AFS OKAY 2 Error stored 6140 A0 CE99 20
17 EKP OKAY No Error stored
18 EGS OKAY No Error stored
29 DSC OKAY 1 Error stored 5EBA E0
ADR Gen. name JobStatus ZB No. VIN No. Date
00 ZGM OKAY 9221109 CU00042 26.10.2009
01 SIM/SGM OKAY 9172018 CU00042 26.10.2009
02 SZL OKAY 9204511 CU00042 26.10.2009
12 DME/DDE OKAY 8509265 CU00042 26.10.2009
16 AFS OKAY 6788165 CU00042 26.10.2009
17 EKP OKAY 7276382 CU00042 09.09.2011
18 EGS OKAY 7603576 CU00042 26.10.2009
29 DSC OKAY 6783362 CU00042 26.10.2009
38 EHC OKAY 6784314 U000422 26.10.2009
3F ASK OKAY 9185549 CU00042 26.10.2009
40 CAS OKAY 9237046 CU00042 09.09.2011
41 DWA OKAY 9149674 CU00042 26.10.2009
44 SHD/MDS OKAY 9137055 CU00042 24.08.2006
47 ANTTU OKAY 9185625 CU00042 26.10.2009
55 ISPB OKAY 9229740 CU00042 09.09.2011
5E GWS OKAY 9212220 CT51209 19.08.2009
60 KOMBI OKAY 9194889 CU00042 26.10.2009
62 MOSTGW OKAY 9185627 CU00042 26.10.2009
63 MMI/CCC OKAY 9185624 CU00042 26.10.2009
64 PDC OKAY 9185139 CU00042 26.10.2009
65 BZM/SZM OKAY 9183233 CU00042 26.10.2009
67 ZBE OKAY 6944884 ÿÿÿÿÿÿÿ 10.01.2007
6B HKL OKAY 7188110 ÿÿÿÿÿÿÿ 12.12.2007
6D FAS OKAY 9196932 CU00042 26.10.2009
6E BFS OKAY 9196932 CU00042 26.10.2009
70 LM OKAY 9203081 CU00042 26.10.2009
72 KBM OKAY 9176070 CU00042 26.10.2009
73 CID OKAY 9151979 CU00042 26.10.2009
78 KLIMA OKAY 9248708 CU00042 09.09.2011
A0 CCC OKAY 9193880 CU00042 26.10.2009
Thanks
Thanks
kurtb23
04-22-2015 04:30 PM
turbogate
04-11-2015 05:02 PM
