Central locking/tailgate not working with keys
Old 12-27-2010, 11:29 AM
xiTouring's Avatar
The central locking/tailgate remote features are no longer working on my 2006 530xiT. I checked all of the fuses which and they are fine. Inside, I am able to use the dash buttons to lock/unlock the doors as well as open the tailgate however both remote functions with both keys are out.
Thanks for any thoughts!
Old 12-27-2010, 12:09 PM
AJH
AJH's Avatar
Hi,
The wires running through and near the rear tailgate hinge become brittle and corrode after time caused by the action of lifting the doors up and down. The wires in question are the ones on the right hand hinge of the smaller glass door.
I had exactly the same problem as you and decided to have a go at fixing it myself, found three broken wires, replaced the perished sections of wire and now she works perfectly
If you search these forums I'm sure there is an explanation of how to do it somwhere.
Cheers
Old 12-27-2010, 12:13 PM
AJH
AJH's Avatar
Originally Posted by AJH
Hi,
Cheers
Oh yeh,
Dont go to a dealer! I've read storys of people being qouted 1000's for new wireing looms :thumbsdown:
Old 12-27-2010, 12:15 PM
xiTouring's Avatar
Oh yeh,
Thanks for your reply AJH. I wonder if it's covered under the USA CPO warranty???
Old 12-27-2010, 12:18 PM
AJH
AJH's Avatar
Havn't a clue, I'm from the UK
Old 03-13-2011, 12:04 PM
gravity's Avatar
Probablu defective Diversityantenna.
Old 03-20-2011, 10:47 AM
Dandle's Avatar
My Ride: 07 E61 530d M-Sport.
More likely the diversity antenna than broken wiring if the locks are still working from inside the car. Water gets into it and over time the range reduces until the remotes no longer work at all. Its located under the rear spoiler if you want to have a look at it.
Old 03-20-2011, 11:52 AM
Spartan335i's Avatar
My Ride: 06' 530xi E61 Saphire Black / Dakota Black - aluminum 11' A4 Avant 2.0T Brilliant Black / Black - aluminum
I had the same problem on mine stopped working from one day to the next. No intermittent issues just stopped.
As others have mentioned the problem was caused by a corroded board and also had an electrical issue a few months later (was the actual wiring loom that had corroded wires). All was covered by the CPO warranty so I'm guessing it should be for you as well.
squints2c
10-06-2022 03:33 PM
chrismanuel
05-10-2015 07:15 AM
160THSOAR
05-01-2015 02:10 PM
macantley
03-31-2015 03:44 PM
james69z28
03-23-2015 06:45 PM
Quick Reply: Central locking/tailgate not working with keys
