CCC to CIC?
just got a new to me 08 535xi wagon. it was made in 05/07. i want a way to play MP3"s. my car doesn't have any USB ports, and only seems to have an aux port in the center console. the port has a sliding cover. all the posts i can find seem to only be people with pre LCI cars upgrading.
my question is can i just add the USB port and appropriate coding, or should i just upgrade to CIC? i don't have, nor will i ever have an IPhone. all i am interested in is playing MP3's and watching DVD's while on long trips. i can't find any precise answers from Google. please help. listening to the radio is slowly killing me. |
CIC won't help you stream bluetooth either. Look around this forum, there are bluetooth adapters you can use and power it with the USB port in the center console, next to the 3.5mm phone jack. That would be your only option if you have those items in the center console.
Carly sells an Install-on bluetooth receiver as well but I'm not sure it is for a CCC...it might, check them out too. |
This works perfectly......
Your phone can hook up to that along with the cars bluetooth for phone at the same time, it will auto connect, auto stop your music when you turn the engine off etc. |
The only thing I would add is, the charger it came with interfered with FM and AM reception in poor signal areas, also DAB, but I am in the UK not sure on whether it would do that to Sirrus?
But then so do so many chargers, especially dash cam ones. The one I have found to not do so is this Belkin.. Can't find it on its own, but someone selling the pack for $12. |
i guess i wasn't clear enough as to what i was wanting to do. i currently do not have any USB port, in the glove box or center console. all i want to do is add the OEM USB port to the center console so i can use a USB thumb drive to listen to MP3's from. since i should have a system capable of that option, all i should need to do is get the needed hardware and code my car to recognize the USB port, right?
OK, then CIC will do the trick...but it is slow because every time you restart the car the USB has to re-index all songs, so if you have a 128 GB stick filled with songs it might be 5-10 minutes before you can start playing songs. CIC (coded properly) will also let you watch DVDs while driving...not recommended for driver though ;)
I think at this point your best choice (and cheaper) would be to upgrade to Android system with touch screen https://avinusa.com/8-8-bmw-5-series...on-system.html |
My advice? Playing MP3s has become passé. I'd suggest investing $20 bucks in an easy-to-install Bluetooth board as described in this thread. I have free Pandora, Spotify and Amazon Music accounts that provide all the music you could ever listen to + podcasts if you're into that sort of thing.
Originally Posted by pocholin
(Post 1597389)
I think at this point your best choice (and cheaper) would be to upgrade to Android system with touch screen https://avinusa.com/8-8-bmw-5-series...on-system.html i was looking at the AVINUSA system you linked. however it didn't specifically mention adding a USB port and what not. guess i will need to look more into it.
Originally Posted by JayArras
(Post 1597390)
however, i will look more into the link you provided. |
Another option is...do you have the in-dash CD player? Your could burn your MP3s to disk and play them that way. I did that for years.
that's what i have been doing now. i got some CD-R's, and put some MP3's on one. its the least, worst, option right now. it will tide me over till i can figure out what i want to do. FYI the DVD player doesn't recognize MP3's. that's the first thing i tried.
| All times are GMT -8. The time now is 04:09 AM. |
