Breyton gts-r info
How's it going guys, Im new to the forum and was wondering if all the research I did for this fitment will work. I own a 530 wagon AWD and I'm looking into Breyton Gts-r 20x10 rear 20x8.5 front.285 rear tire, and a 245 front tire. Would anyone change these specs ? Also who is a good contact to purschase the wheels from ? Thanks in advance.
Ethan
Ethan
from what I've read its et25 rear and et18 front - Ive also seen some go et20 rear - im not really sure on the exact offsets but to give you an idea this is the look Im going for. Any info on this car would be greatly appreciated. What lowering springs, wheels, tires, and offsets - Im in love with this car !
My Ride: 2010 VW Passat Wagon 2.0l Tsi
Grey/Grey Budapest 18"
Lost to HPFP issues:
08 535i sport pkg
Lost to Dreaded E61 Sun roof leaks:
07 E61 530Xi
The off set are not enough....
Also Lowering springs =Bad...
The E61's have Air springs in the rear, so the only recommended option is Coil overs.
the offsets I think are et22 front and et17 rear - 20x9 front / 20x10 rear - does breyton make this offset and sizing ? running a 295/25/20 rear and a 255/30/20 front
My Ride: 2006 Audi A8 4.2TDI
Previous rides:
2005 E61 530d, 20" Breyton reps, Eibach springs, M5 bumper/mirrors/MFSW
2000 Audi S6 Avant, 18" OZ, RS6 exhaust etc
1998 Audi A8 4,2Q, 19" RS4 wheels, Remus exhaust KW coilovers etc
1986 Audi 100CC, funky fresh steel rims w plastic covers, rubber lip on boot.....
1987 BMW 320i, 15" alloys + rubber lip on boot :)
1982 Opel Ascona 1,6DL, tinted windows and a big-ass subwoofer :P
For lowering I run the Eibach Pro kit with standard shocks in the front and the rear dropped by programming only. Works perfect to date. Not too agressive lowering but I need some clearance for the sh*tty roads in Sweden. The GTS-R are awesome wheels btw
Previous rides:
And be careful about the front setup. I run 9x20 ET20 with 255/35s and I need 5mm spacers to clear the spring support on pass.side. Maybe you'll get away with the 30 profiles but just wanted to give you a heads up
08 535i sport pkg
07 E61 530Xi
They do for the RWD ones in Europe...
Watch out for some of the info given here since most of the European drivers are in RWD cars while all the E61's in the USA and Canada are AWD and have different wheel and suspension set up's.
