530xi axle
After I lowered my car, the front left axle came out while I was driving. This happened three times already in a month. Anyone has the same problems? How can I fix this?
My Ride: 530xi Sportwagen
Engine: N52
Something is REALLY wrong. There should not be that much tension pulling on the half-shaft. Check all your dimensions, as the only thing I can think would cause the joint being torn apart is some kind of frame damage, or replacement control arms that were too long for the car.
Jose
Jose
My Ride: 2008 535xI Wagon
Engine: N54
that's what happens when you lower an xi. you either need to raise the car up a bit, to keep the joint in its happy place, or get a custom axle made with a longer shaft.
NYC530XI
11-04-2009 01:56 PM
