2009 E61 Door trim removal
My Ride: 2012 F10 550i, 2001 e46 325i Sedan, 2009 e61 335xi, 1986 325i
I'm sure I'll get blasted, but I swear I've searched (potentially with incorrect terms) for the answer to this on this forum.
Do I need to pull the doors to get this trim off - or do they just pop off with trim removal tools? Obviously, I don't want to try to pry if they're bolted on![Wassat](https://5series.net/forums/images/smilies/imported/wassat.gif)
See attached.
Thanks in advance.
See attached.
Thanks in advance.
My Ride: 535XIT Space Gray, Cream Beige LeatherCold Weather, Premium, Auto, Rear Side Window Shapes, Heated Rear Seats, Park Distance, Navigation, Satellite Radio
Model Year: 08
I thought that you always wanted to keep the battery concected?
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Agree on disconnecting the battery.
On this car (2009) these trim panels are incredibly hard to remove, no way you could do it without removing the door cards. Even then, it is really difficult to remove these as they're not simply snapped in, these trim pieces are held in with circular ring clips which by themselves are ridiculous to remove even with the door cards removed. I scrapped the idea of removing the trim and will be covering the trim in-place without removing the trim. Not ideal. but better than replacing them all due to breaking them while trying to remove them.
