Left Front Parking Light Malfuction - Angel Eye Replace?
Old 12-24-2012, 02:35 AM
subterFUSE's Avatar
Default Left Front Parking Light Malfuction - Angel Eye Replace?
2005 BMW 545i SMG 99,850 miles. Purchased 11/2004.
Yesterday I received an iDrive notification that my left front parking light is malfunctioning. I have the active xenon headlights.
Visual inspection revealed that my angel eyes on the left side are out. My car is long out of warranty, and I am suspecting that a dealer fix for this would be a full light replacement and very $$$$.
Would this be a good time to consider an aftermarket angel eye upgrade?
I'm wondering if I could order something like the AngeliBright and do a far less expensive DIY fix?
Or do you think there might be something more wrong that an angel eye upgrade won't fix?
Looking for advise, guys. Thanks in advance.
Old 12-24-2012, 09:26 AM
constant's Avatar
Nm, was going to suggest new H8 bulb but you are pre-LCI. Can you swap bulbs from left to right, and if it's simply the bulb order a new set (either OE or upgrade)?
Old 12-25-2012, 12:44 PM
subterFUSE's Avatar
Now the iDrive warning is gone, and the angel eyes are working.
I just had a software update done to the car a few days ago. Wonder if that has anything to do with this?
Old 12-26-2012, 05:12 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
hopefully it's just a loose connection at the bulb. if you do need bulbs, you can get a set of LEDs for about $60. I have a set of brand new stock bulbs that I'll sell you for $20 if you want to go that route. New OEM bulbs are around $25 each IIRC.
I'll mention this too: remove the round access cover and inspect the wiring inside of the headlight housing....
socale39
09-05-2023 08:30 AM
Tsoup
15
12-20-2021 11:14 AM
Kasmo
05-07-2019 03:30 AM
rkilpa
03-10-2015 08:24 PM
08-12-2003 11:41 AM
Quick Reply: Left Front Parking Light Malfuction - Angel Eye Replace?
