CIC Retrofit Installation LOG
Old 09-26-2013, 01:46 PM
  #1011
djcwardog's Avatar
My Ride: 2007 E63, loaded, 6M, Sport, CIC/combox, DIRAC retrofitted.
Originally Posted by ptikkala
ok so just a little write up about my lci ihka install. Car is 530d 2006/01 (Ihka high from factory)with CIC retrofit....btw. anyone know what happened to great bmwcoding.com forum???
My pre-LCI IHKA panel is OK for now, but an LCI update may be in order...
I believe the bmwcoding forum dropped of the net for just a bit - they are back now though...
Old 01-20-2014, 01:25 PM
  #1012
carpoolman's Avatar
My Ride: E60 ful loption
Hi Guys,
just a quick thx to the guys at bimmertech (Patryk and MEN for coding).
.order of combox and USB/aux (E60 LCI model) arrived on Friday thx Patryk for quick delivery.
. Saturday combox in trunk, coding done by MEN thx for that.
-Monday install of usb/aux. @Rootkit thx for youre DIY that I get from Patryk.
thx a lot Patryk and Men for the support/communication and good service.
Greetings, Abdel
Attached Thumbnails CIC Retrofit Installation LOG-foto-1-2-.jpg   CIC Retrofit Installation LOG-foto-2-2-.jpg
Old 02-08-2014, 05:55 AM
  #1013
italy530's Avatar
My Ride: 530d LCI 2007 Msport
Originally Posted by Georgieb
There is an insert for the USB connector which is used in the same place that your flashlight currently sits. I decided to just let my port hang in the glove box as I never did get around to purchasing the USB insert mount. I can't remember what the part number for this bracket it but I'm sure its hidden with this thread somewhere.
If you are referring to the iDrive contoller swap, then I do not believe additional coding is required although the wiring harness and conductor pinout will have to be changed. If you are refering to your CIC, then coding is definately required. It may be best that you ask Patryk's advice on this.
Cheers
hello I would like to apologize for an info event then you have found this article code USB
Old 02-18-2014, 01:22 PM
  #1014
bmwrider2010's Avatar
My Ride: BMW 550i
can someone give an idea how to retrofit CIC controller as it doesn't look plug and play on my 2006 with CCC. old controller has two connectors one is wide for controller and small 4 pin for button. new CIC controller has 4 pin connector only some one said it is plug and play how is that possible? see picture attached
Old 02-18-2014, 01:35 PM
  #1015
My Ride: BMW 550i
found an answer myself. remove wires 1 2 4 5 from wide connector and stick them into small 4 pin (button) connector in order 1 2 3 4 seal the rest plug new CIC controller and you are done
Old 02-19-2014, 04:51 AM
  #1016
italy530's Avatar
hello I would like to purchase the cic for a e60 lci but they tell me that if I mount the buttons do not light up the cic. and true or is there a solution for this problena
Old 02-19-2014, 04:54 AM
  #1017
ncsugrad2006's Avatar
There is a solution. One wire from the CIC has to be connected to another 12V source that is switched with the lights. Most commonly people use the buttons on the lock button/hazard button switch between the air vents in the middle of the das.
Old 02-19-2014, 05:24 AM
  #1018
italy530's Avatar
and you can not move the pin that first lit up the keys of the CCC?
Old 02-19-2014, 05:26 AM
  #1019
I would assume the lights must be switched on differently or someone would have done that already
I do not have an LCI model to test on though, so I'm not all that familiar with it. I just remember seeing people do the fix in other CIC retrofit threads (and this one too I think)
Old 02-19-2014, 07:53 AM
  #1020
italy530's Avatar
I understand that's what year responded bimmerretrofit
Good day Francesco,
I apologize but we cannot email any instructions or technic description before you become our customer and place an order.
As for the light pelase do not worry. We have sold over a thousand CIC kits for E6x series and I can ensure you that lights fix can be done by you. It is our unique method which our engineers developed for all E6x series use.
Regarding the LCI climate panel - if you sure that your vehicle already have LCI panel then you do not need to worry and you will not need to change panel.
Only if your vehicle comes with pre-LCI panel then you need to change it if you want to have all functions working with iDrive.
Thank you,
Kate Ivanova
Customer Relations
Bimmer Retrofit
________________________________
Quick Reply: CIC Retrofit Installation LOG
