Are update headlights compatible on 2005 M5 E60.
Old 03-26-2013, 05:06 AM
Ren5turbo2's Avatar
Default Are update headlights compatible on 2005 M5 E60.
Are the update headlights compatible with my 2005 M5 E60.
Old 03-26-2013, 05:14 AM
BlaSTiWi's Avatar
If you mean newer LCI headlights ... yes I've done it (granted my car is not 2005) ... for properly done you'll need newer Light Control Module (LM2) you'll need the headlights (of course) + the taillights and BMW OEM retrofit wiring ... after that you have to re-wire the plugs 'cuz they are different ... and finally do some coding.
Old 03-26-2013, 05:22 AM
Ren5turbo2's Avatar
https://5series.net/forums/e60-parts-accessories-mods-22/pre-lci-halogen-lci-halogen-conversion-103684/
Thank you i found this link
Old 03-26-2013, 05:23 AM
Ren5turbo2's Avatar
Is there anyone in Australia who has the knowledge to do it and whats involved in the coding.
Old 03-26-2013, 05:25 AM
Ren5turbo2's Avatar
I asked my local dealership, canberra , and they said it wasnt possible. But I think they were not confident enough to do it.
Old 03-26-2013, 05:34 AM
BlaSTiWi's Avatar
Just remember ... your headlights are Xenon and likely Adaptive the link is about halogen.
As far as conversion cable ... as I've done this before ... I would recommend cut the wires and replace the plug to avoid any potential problem ... but hey that's just me.
Old 03-26-2013, 05:37 AM
Ren5turbo2's Avatar
Oh thanks for pointing that out. Is the coding difficult?
Old 03-26-2013, 05:39 AM
Ren5turbo2's Avatar
Im just not confident carrying this out, im sure ill break something, I wish there was someone in Australia who had done the conversion who could help.
Old 03-26-2013, 05:41 AM
BlaSTiWi's Avatar
Well it depends ... if you know get around setting things up it's not difficult but if you mess things up you could render killing some of your car module(s) ... since this conversion you have to change your Vehicle Order (VO) which is the DNA map of how your car born.
Old 03-26-2013, 05:43 AM
BlaSTiWi's Avatar
Well your local dealer is clueless ... the conversion is actually came from BMW as an official OEM retrofit the manual, the cable kit etc ... all has BMW part number.
They probably afraid of amount of work it has to be done ... but if you going with dealer such conversion could cost you a lot of money.
Quick Reply: Are update headlights compatible on 2005 M5 E60.
