Steering Column for 2008 528i
My Ride: 2010 535i M sport
Model Year: 535i / 2010
I have a catch or "bump" when turning the steering wheel in either direction. I took it to the dealer and they said the steering colum will need to be replaced. They want $700 to do so. I am trying to avoid having the dealer fix this problem. I read on other posts that others have lubed the column to fix this problem. Does anyone have a DIY or photos of where to look so I can attempt to fix this problem myself?
Any advice or help is greatly appreciated! Thanks.
My Ride: 545i
Engine: N62
OP,
Welcome to the Forum. Unfortunately you are in the wrong section. Not only is this the M5 Discussion Forum, it is also not the DIY Forum. I'm sure a moderator on the Board will move this post for you. I would check the DIY Section or perform a search for this question. Good Luck!
sg530
Nov 6, 2025 06:06 AM
philb
Apr 18, 2015 07:49 AM
