M5 Product Guide.
Old 10-17-2005, 10:05 PM
  #21
cidair's Avatar
According to a engineer at BMW M, you will loose 10 - 12 hp if you run the M5 on 95 octane instead of 98 octane ( 98 is the recommended ).
Old 10-18-2005, 06:47 AM
  #22
wolverine's Avatar
[snapback]185557[/snapback]
Of course I hope you asked him if you would GAIN any HP with higher octane??
I'm guessing not, but we can hope...
Old 10-18-2005, 09:35 AM
  #23
robg's Avatar
My Ride: 2008 550, Carbon Black Metallic, Natural Brown Dakota Leather, Sport Package, Sport Automatic Transmission, Cold Weather Package, Power Rear and Manual Side Sun Shades, etc. Retired - 2004 545 SMG, Black Sapphire Metallic, Auburn Dakota Leather, Cold Weather and Sports Packages, Power Rear and Manual Side Sun Shades
Originally Posted by wolverine' date='Oct 18 2005, 09:47 AM
[quote name='cidair' date='Oct 18 2005, 12:05 AM']According to a engineer at BMW M, you will loose 10 - 12 hp if you run the M5 on 95 octane instead of 98 octane ( 98 is the recommended ).
[snapback]185694[/snapback]
[/quote]
That is a topic that has been hotly debated in the main forum. I say no, and think the science supports me (i.e., the engine is designed to work at a specific compression ratio and you cannot receive any additional benefit merely becasue the gas you use can, in a different engine or environment, be compressed even more). Others, including Iceman, insist higher is better. I have still never seen any empirical evidence that higher than recommended octane provides a benefit.
Old 10-18-2005, 10:02 AM
  #24
wolverine's Avatar
Originally Posted by robg' date='Oct 18 2005, 11:35 AM
[quote name='wolverine' date='Oct 18 2005, 09:47 AM'][quote name='cidair' date='Oct 18 2005, 12:05 AM']According to a engineer at BMW M, you will loose 10 - 12 hp if you run the M5 on 95 octane instead of 98 octane ( 98 is the recommended ).
[/quote]
[snapback]185770[/snapback]
[/quote]
You can't change the compression ratio, but you can change the ignition timing and air/fuel ratio with a higher octane fuel.
From a good site on combustion chemistry:
"If the mixture in a gasoline engine ignites before the spark plug fires, we call that "pre-ignition." Pre-ignition can damage an engine before you finish reading this sentence.
What we're really concerned with is called "knock" and that's the spontaneous ignition of the fuel-air mixure ahead of the flame-front as a result of the rise in cylinder pressure caused by the onset of ignition (caused by the firing of the spark plug). "
Higher octane fuels can allow a more advanced ignition timing, because they are more resistant to 'knock'. This is one of the reasons that aftermarket chip manufacturers can achieve higher HP numbers with very high octane fuels. They're not changing the compression ratio, they're able to change the A/F ratio and the ignition timing.
I agree with you, and doubt BMW has programmed the M5 to take advantage of a higher octane fuel, but it's possible.
Old 10-18-2005, 11:33 AM
  #25
cidair's Avatar
The same engineer told me that you don?t gain any hp?s from higher than 98 octane on the M5!
The only time higher octane fuel ( SHELL V-power 100 octane is now introduced in Sweden at 0.1 euro/L more than the old 98) would give you any advantage is during high temperatures ( 25 - 30 deg C and higher ). This advantage is ofcourse only that you don?t loose any hp?s!
Old 10-18-2005, 11:45 AM
  #26
robg's Avatar
Originally Posted by wolverine' date='Oct 18 2005, 01:02 PM
[quote name='robg' date='Oct 18 2005, 11:35 AM'][quote name='wolverine' date='Oct 18 2005, 09:47 AM'][quote name='cidair' date='Oct 18 2005, 12:05 AM']According to a engineer at BMW M, you will loose 10 - 12 hp if you run the M5 on 95 octane instead of 98 octane ( 98 is the recommended ).
[/quote]
[/quote]
[snapback]185776[/snapback]
[/quote]
I undersatnd the basic of the combustion engine and the role of compression, but I am in no way an expert. So some quesyions:
If you change the ignition timing to delay ignition, will the engine create higher/more compression and if so, do you run the risk of damaging the engine if no other mods are made?
If dealy does not create higher compression, is there a benfit?
I think I undersatnd the benefit of changing the A/F ratio, and that very high octane fuels can combust with less air, thereby creating more power. But agin, if you tamper with the mixture without making other mods, do you run the risk of engine damage?
Old 10-18-2005, 12:44 PM
  #27
wolverine's Avatar
Originally Posted by robg' date='Oct 18 2005, 01:45 PM
[quote name='wolverine' date='Oct 18 2005, 01:02 PM'][quote name='robg' date='Oct 18 2005, 11:35 AM'][quote name='wolverine' date='Oct 18 2005, 09:47 AM'][quote name='cidair' date='Oct 18 2005, 12:05 AM']According to a engineer at BMW M, you will loose 10 - 12 hp if you run the M5 on 95 octane instead of 98 octane ( 98 is the recommended ).
[/quote]
[/quote]
[/quote]
[snapback]185839[/snapback]
[/quote]
Here's a website that gives a good overview of combustion chemistry, and the effect of octane, temperature, and ignition timing:
http://www.faqs.org/faqs/autos/gasoline-fa.../section-1.html
Here's the point I was making earlier:
"The tendency to knock increases as spark advance is increased. For an engine
with recommended 6 degrees BTDC ( Before Top Dead Centre ) timing and 93
octane fuel, retarding the spark 4 degrees lowers the octane requirement to
91, whereas advancing it 8 degrees requires 96 octane fuel [27]."
Basically the earlier you can start the spark, the more complete your combustion will be, and the more power you will get, so you want your ignition timing advanced as much as possible, to the point just before you would get 'knock'.
Old 10-18-2005, 10:00 PM
  #28
Centurion's Avatar
My Ride: 545i; Manual Shifter
So, considering all that has been mentioned so far, does BMW have to retard the ignition for all the M5's sold in California (and other states) where the highest widely available octane is 91? If so, doesn't this mean less than optimal engine performance (i.e. <500HP)?
The reason I ask is because of this quote:
Old 10-19-2005, 05:40 AM
  #29
robg's Avatar
Originally Posted by Centurion' date='Oct 19 2005, 01:00 AM
So, considering all that has been mentioned so far, does BMW have to retard the ignition for all the M5's sold in California (and other states) where the highest widely available octane is 91?? If so, doesn't this mean less than optimal engine performance (i.e. <500HP)?
[quote name='cidair' date='Oct 17 2005, 11:05 PM']According to a engineer at BMW M, you will loose 10 - 12 hp if you run the M5 on 95 octane instead of 98 octane ( 98 is the recommended ).
[snapback]186044[/snapback]
[/quote]
To the best of my knowledge, BMW does not adjust the timing based o the region. New engines will automatically adjust to prevent knock and damage, and there will be less than optimal performance.
Old 10-19-2005, 02:09 PM
  #30
Centurion's Avatar
Originally Posted by robg' date='Oct 19 2005, 06:40 AM
[quote name='Centurion' date='Oct 19 2005, 01:00 AM']So, considering all that has been mentioned so far, does BMW have to retard the ignition for all the M5's sold in California (and other states) where the highest widely available octane is 91?? If so, doesn't this mean less than optimal engine performance (i.e. <500HP)?
[/quote]
[snapback]186107[/snapback]
[/quote]
This is my thought too. :thumbsdown:
Quick Reply: M5 Product Guide.
