ECU REmap
#21
My Ride: 2007 M5 - Interlagos Blue / SMG / Black Perforated Merino / Fully Loaded!!
Originally Posted by EuroCarFan' post='1040590' date='Oct 26 2009, 10:31 AM
What do you mean by reset? You can go in an change any of the parameters in the MDrive settings.
#22
Originally Posted by designo' post='1039370' date='Oct 24 2009, 04:30 AM
Damn it!
I wanna have optimum performance at the press of my M button. But I drive in P400 S1 mode 90% of the time.
This sucks!
This sucks!
#23
Originally Posted by smokescreen-38' post='1040615' date='Oct 26 2009, 11:10 AM
I could be wrong but I think Aartsy19 was referring to the transmission reset like on the auto or steptronic models..
Yes Sir
#24
Originally Posted by designo' post='1038834' date='Oct 23 2009, 10:03 AM
That's cause your butt muscles are getting stronger!
#25
Originally Posted by C's Bimmer' post='1039269' date='Oct 23 2009, 11:01 PM
You do know that the computer picks up on your driving habits and style and "builds a profile" around that style, right? For example, if you never drive in M Mode with P500 Sport, and only drive in P400, your car will seem slower than someone's M5 that always keeps it in M Mode and P500 Sport, such as myself.
Doesn't really make any sense!! Wouldn't it be the complete opposite as the person driving the car under full power would be wearing down the car quicker, making it slower?
#26
Originally Posted by m630' post='1037387' date='Oct 21 2009, 09:43 AM
As the cars a basically mechanical computers, there are opportunities to rewrite or 'tune' some of the aspects of the program running your engine vitals.
Below is Dinan's description to give you an idea of what can be done:
Dinan Engine Software raises the factory rev-limiter by 150 rpm (8400 rpm maximum), endowing the V-10 with a broader power band and greater road speed potential in each gear. The software also removes the top speed governor, enabling the cars to attain their ''natural'' top speed; and the V-10s WILL pull right to red-line in top gear! The software also speeds up throttle response, providing a sportier feel and improved modulation capabilities.
The combination of Dinan's re-calibration of ignition timing and air/fuel ratios, along with a simple modification to the stock air filter elements, produces a maximum gain of 5 hp @ 8100 rpm and 5 lb-ft torque @ just 3000 rpm. Dinan's software also provides re-calibration of the factory ''torque limiting'' programming, ensuring that maximum power is available under varying driving conditions.
In the US, a Dinan authorized dealer can do this and its warrantied by Dinan, but others are not done at the dealership and are not warrantied...
Sorry to hear that you are putting the beast away for the winter, too much fun for me to do so!!!!!
But are these upgrades by Dinan recommended to someone whose M5 is close to warranty expiration? I am worried that i'll do something to my car (exhaust,pulleys,blockoffplates,scoops and now ECUremap) and then it will have a negative effect, causing me $$$@ the dealership.
Basically my question in rebuttal is; Is the ECUremap worth the value with the increased risk of negative effect on the car a factor? if there even is a risk?
Thanks,
Aartsy
#27
Originally Posted by Aartsy19' post='1040973' date='Oct 26 2009, 06:55 PM
Sorry to be so late on this reply, and probably should have included these comments in the previous post...
Thanks,
Aartsy
Thanks,
Aartsy
Now if you have parts from other companies thrown in there, then yes, there's a chance you'll have problems at the dealers if they determine that one of those tuner parts caused the failure of the part being claimed for warranty work. In the US, we have the Magnusson-Moss Act that protects consumers and basically states that dealers can't void a warranty unless they can prove that an aftermarket part caused the failure of the part being claimed for warranty work. I don't know if Canada has something like that.
Although I have not heard people having issues with their dealers regarding aftermarket parts, I'm sure it can happen. And I also haven't heard much about aftermarket parts causing negative effects on people cars but logically, that could happen. The more your car is modded, the more it's being pushed to the tolerance levels of its parts. That said, most bolt on mods like what you've listed above should be relatively safe.
