DeTuned LC
#31
Originally Posted by ///MAlhadeff' post='211415' date='Dec 14 2005, 10:26 PM
i just bought my M5 3 days ago with 1700 miles on it, so the full power is availalbe. I can assure you all that the acceleration time from BMW are very modest. I have raced many cars so far, and done numerous runs, including my friends 996TT X50. 5 times the M5 wins, from a roll and from a standstill. I have a 996tt as well and immediately I could feel that the M was faster from the first drive.
launch control isnt even necessary, if you are in 1st gear with smg 6 and dsc off, if you just mash the pedal from a standstill it will light them up, hook up, and take off chirping 2nd and 3rd gear upshifts. All I can say is this is the best BMW street car ever, and Ive heard a rumor that Dinan has squeezed over 600bhp already from ecu and exhaust![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
I did many laps with my M5 when it was stock. at Willow Springs 2 days ago, and can assure you that it is faster than my 996tt The brakes, turnin in response, weight transfer, and acceleration is unbelievable for a sedan, you forget what kind of car you are driving.
#32
My Ride: 545i; Manual Shifter
Originally Posted by vnod' post='212883' date='Dec 18 2005, 12:21 PM
Weclome. I am glad your car performs so well. I am hoping that you will take it to a dragstrip and let us know how you do. But, note that the issue with getting good strip times is now whether one can produce tire smoke. Many can easily smoke their tires with relatively few RPM, but good strip times often take many RPM--especially with a low-torque engine like the M5's. I am interested in an M5, but definitely will wait for the manual to even think about getting serious.
I know you place straight-line acceleration very high on your list. Here's something I thought might be interesting, but honestly have not given it much thought...
Speaking only in terms of launching from stand still, the M5 with SMG will be slower off the line than the same car with a manual (assuming with the manual you are holding the motor at the optimal RPM before engaging the clutch). However, the SMG equipped M5 will have quicker shifts between gears. You'll probably need to shift to 4th gear in a 1/4-mile run, hence AT LEAST 3 shifts).
Here's the question: Do you think those 3 shifts are quick enough to catch up to the manual shifting M5 which, theoretically, is already out in front?
My initial assumption is, "No". The jump at the line is enough to take the manual shifting M5 across the quarter-mile first.
Any thoughts, or am I just drinking too much of Grandma's eggnog?
#33
#34
Great issues to think about Pennyurion.
Yep, I got stuck in the 50's and 60's. Yea! I'm kidding, of course. I like curved lines too. But, I find time and places for straight lines.
I think a good driver with a manual can launch better than an SMG with LC disabled at least. I am not sure what would happen with a full load of LC. I still think the manual driver still would have a slight advantage if a launch above 4k is indicated, given track conditions, and because of the manual driver's ability to use his accelerator/clutch combo, perhaps, closer to optimally than the SMG driver can. In this regard, I am assuming that the SMG will shift at the optimal RPM, but I am unsure that this scenario will play out since shifting below redline actually might be optimal. In sum, I think that at least a good power shifter can keep up with an SMG in shifting--closely enough no matter what. And, from the C&D results, it looks like both cars would need to shift 3 times.
As my thoughts above imply, I don't think the SMG would catch the manual. I do think that the race should be a very close one. And, I think the manual driver needs to be a good driver and maybe would need to powershift. I would like to think that powershifting would not be required because, if I ever get an M5, then I would want the theoretically fastest one without having to powershift. In this regard, I don't want an SMG since I want smooth shifting most of the time and relatively few problems and complexities out of my tranny.
My "best" opinion is that the manual will win without powershifting given a good driver. But, it should be very close. In this regard, I am not convinced that the SMG would be catching even the non-powershifter. I know that I, for one, can shift very quickly without powershifting--and I have no reason to think that I am the fastest non-powershifter.
I have one more thought supporting the close-race idea--with the manual winning. I doubt that BMW chooses the rear-end ratio for the manual cars optimally. I suspect BMW doesn't want the manuals to be faster than the SMG's. And, note that BMW's times for manuals and SMG's always seem to be the same in recent history. One the other side of the coin, I'd bet that BMW's drivers don't dirve the manuals as well as good old US drag racers do--even without powershifting.
I think that one can drink too much of anything.
[/quote]
P.S. I don't think it would matter except for the optimal shift-points issue, but are you assuming the SMG will be shifted manually or automatically?
#35
It don't recollect this being mentioned associated with the NA crippled LC but there is another feature that is apparently missing. An automatic shifting at optimal RPM all hands off courtesy of LC. If available as it is in ROW M5s would appear to me to further optimize a ? mile time/speed. Not having either M5 it is hard for me to judge. That to me would be the best litmus test is to pit the two versions of M5 against each other (and swapping drivers) rather than having to depend on times in different locations or antidotal stories about beating this 997 this or SL that.
#36
#37
At any rate, I believe the actual time it takes for the SMG tranny to lift the clutch, select a gear, and re-engage the clutch (in other words, the dead-time between gearshifts) is the same whether it is being shifted manually or automatically. I'm not sure of the current SMG III technology, but the previous SMG II took 0.8seconds between upshifts (as reported by BMWNA).
Now here is what I've got from the "2006 M5 Product Information" catalog:
In the sportiest program of all, S6, the minimum shift time has been reduced 20% from that of the existing SMG, which was already very fast.
Therefore, approximately 0.6seconds between shifts in SMG III. (?)
All that being said, I still think the manually shifting M5 would take the 1/4 mile.
You bring up an interesting point about the rear-end ratio. I wonder what BMW will do with the gearing of the manual shifting M5 because that introduces yet another variable.
#38
[/quote]
Yep, and it is "the" critical variable--game, set, and match possibly to the car that comes closest to having the optimal ratio--assuming BMW does not try to more or less equate the performance levels of the two cars. The outcome of the race will be something of a crap shoot if BMW wants to "equate the ratios."
