Will these fit on my e60??
My Ride: Jan 2006 E63 650i Sport
Options:
Sport version (includes: sport-seats, sport-suspension, M-Sport steering wheel, Anthracite headliner, Shaddow Line), Saphire Black, Black Dakota Leather, Anthracite Maple Wood trim, Steptronic Auto, Xenons, NAV-Professional with Voice Control, TV, CD-Changer, Bluetooth, Logic7, Head-up Display, Comfort Access, Seat Heating front, Auto Dimming & Folding Mirrors, Extended Auto Air Conditioning, PDC.
Mods:
Spacers 5mm front & 15mm rear
Wheels:
20" Alpina Softline (Classic) with Dunlop Sport Maxx non-RFT (255/35/20 & 285/30/20)
The front should not be an issue, because the 7er rim is a half-inch wider but the ET (hub depth / offset) is 6mm greater and therefore compensates for this. They tyre sizes are also the same as on the E60. So that's all fine.
On the rear however, it could be a tighter squeeze, because the ET value is lower AND the rim is wider. So the ET value will push the rim out further and the rim is wider. Not sure if you could fit a 275 wide tyre on the 10 inch rim to help reduce the risk of rubbing??
HOWEVER, a member has fitted this to their E60 and claimed they fitted ok. I suggest doing a search in the E60 Discussion section. Maybe it will all fit under the rear arch without rubbing
BWM wheel+tyre specs here:
5er E60
8,5x19 front 245/35R19 ET 18
9,5x19 back 275/30R19 ET 32
7er E65
9x21 front 245/35R21 ET 24
10x21 back 285/30R21 ET 24
5er E60
7er E65
5er E60
7er E65
5er E60
7er E65
8,5x19 front ET 12
9,5x19 rear ET 28
The tires for 21" wheels on a E60 should be
245 or 255/25R21
275 or 285/20R21
bestofthebest
03-30-2015 08:12 PM
