Will a lci idrive controller fit and work with a CCC in a pre lci
Old Nov 19, 2011 | 07:35 AM
BallyM5's Avatar
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic, Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release, Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
Hi guys I'm currently getting the bits together to fit my CCC in to my e60
I been told I need a idrive high controller can the lci one from a 2008 car fit my car existing idrive controller wiring
As I need one to use my CCC
The part number I been told is 6944884
Is this a high one just to confirm also thanks a lot so the help so far
Old Nov 19, 2011 | 07:44 AM
BallyM5's Avatar
Looking at the part in realoem it shows loads of different ones with the same part number any idea guys
Old Nov 19, 2011 | 08:45 AM
bruce_miranda's Avatar
If you are going through all this trouble, I would say why not put in the CIC idrive controller itself. It works fine and gives you a lot more functionality than the normal idrive. But otherwise yes even an LCI one will work fine for you.
Old Nov 19, 2011 | 08:48 AM
BallyM5's Avatar
But that means I would need to change my trim and for the lci one I dont do I
So you are saying this is a high controller and it wil work with the ccc
Thanks
Old Nov 19, 2011 | 11:47 AM
NoQuarter's Avatar
Engine: N54
Thanks
You don't have to get new trim. Your existing trim can be cut to fit the new controller.
Old Nov 19, 2011 | 12:45 PM
patrickdsg's Avatar
What about the plug?? Is it plug and play??
I wanna add the new lci iDrive to my 2008 CCC.
Thanks.
Old Nov 19, 2011 | 01:20 PM
NoQuarter's Avatar
Engine: N54
Thanks.
It is not plug and play. The new one is lighted and has different button configuration. Plenty of DIY info around that shows how to modify the plugs and code for the controller.
Old Nov 19, 2011 | 05:34 PM
BallyM5's Avatar
Just to clarify the lci controller with just menu button is direct fit to my controller wiring and panel
And for the new cic controller I need to cut panel and plugs and wire?
Old Nov 19, 2011 | 11:43 PM
correct.
Old Nov 20, 2011 | 01:13 AM
BallyM5's Avatar
Thanks mate
Have these panels got cuts in them already to fit larger controller or is this a hole you make your self by guessing
