Will aftermarket amp make stock subs sound better?
My Ride: Amethest Grey 530i--AC Schnitzer Kit all the way around--Quad Magna Flow Exhaust--20" MMR wheel 4.5 inch lip--
A simple yes or no would be sufficient but if you have experience than by all means explain.
Also anyone with a sub in there trunk is it worth all the work is it a big increase in bass? From my understanding the trunk is so isolated that the bass does not even get through.
My Ride: M3
Model Year: 2017
However, if you are looking for a substitute of a trunk sub then it will not going to happen with the OEM woofers and an aftermarket amp, you will need a pair of SWS-8 and a 300W peak per channel amp.
Awest91
09-17-2022 11:05 PM
incoherent
04-15-2015 04:48 PM
