Wheel Spacers
Old Jun 14, 2009 | 08:38 AM
Mr.Bavarian's Avatar
I recently had my E60 lowered, and installed 25mm spacers at the front and 15mm spacers at the back.
Now I know that this is quite a sensitive topic regarding safety, but as long as you get the H&R spacers with appropriate
length bolts you shouldn't have any problems.
Each wheel bolt will takes up to 1000kg of shear force to break. Our E60s weigh 1.5 tons, you have 25 bolts on the car, easy math.
After I got my spacers done, I had the aftermarket wheels rebalanced and the professionally re-aligned.
I can personally say there is ZERO vibration and handling especially around corners/round abouts have dramatically improved!
Old Jun 14, 2009 | 12:17 PM
Ellicit's Avatar
nice, looks like you did your homework =D
do I need new bolts if I go H&R 12mm? rear?
Old Jun 14, 2009 | 01:24 PM
richard313's Avatar
My Ride: 2006 550i 6spd
25MM in the front?
Old Jun 14, 2009 | 01:29 PM
BlaSTiWi's Avatar
Yeah! could be the wheel has high offset maybe?
Originally Posted by richard313' post='911391' date='Jun 14 2009, 04:24 PM
25MM in the front?
Old Jun 14, 2009 | 04:28 PM
Diamond's Avatar
Banned
bye bye handling
Old Jun 15, 2009 | 10:10 AM
Nick@Jlevi SW's Avatar
Spacers are a great option if the offsets aren't 100% perfect for the car. They give the car a wider look and if you stick with a reputable brand, you can't go wrong.
Old Jun 15, 2009 | 10:13 AM
///M Lifestyle's Avatar
always! take your old bolts measure it and add 12mm to it
Old Jun 29, 2009 | 08:45 PM
John@Motorcepts's Avatar
Banned
My Ride: A Car
do u need longer bolts if u use 5 mm?
Old Jun 29, 2009 | 08:51 PM
E60 545i SPORT's Avatar
My Ride: AW E46 M3 Vert
yes, some might say otherwise but even at 5mm it is recommended. why risk it IMO? the bolts dont cost that much anyway.
Old Jun 29, 2009 | 10:19 PM
etchu's Avatar
better look and less handling, always some compromise.
