Wheel Spacers
Old Aug 1, 2013 | 02:38 PM
satish1015's Avatar
My Ride: none
Default Wheel Spacers
Hey guys, I want to run a set of 15mm wheel spacers on the rear of a 08 550i so I've been doing some research and I came across two types of spacers
Type 1 where the studs are extended
and Type 2 where the spacers bolt onto the original studs and the wheels bolt onto studs already on the spacers
anyone know which one is better/ safer to run and why? I see most users on the forum using the first type.. but in theory shouldn't the second be better? Although I have heard of some issues with the second type.. any advice is apprciated! Thanks!
Old Aug 1, 2013 | 04:35 PM
champaign777's Avatar
My Ride: 2010 550i M Sport
you do realize that you have more weight with the second set
Old Aug 1, 2013 | 07:57 PM
satish1015's Avatar
My Ride: none
I do realize it will be more weight but why would that concern me?
Old Aug 2, 2013 | 11:47 AM
Steveh's Avatar
My Ride: 2010 528i
I ran the seconds for a long time on my 5 lug drift car and never had any issues.
I have ran extended lugs and i HAVE broke those off in the past..
I think the second option you will only have larger spacer options too since it needs the room for the nut to attach to your hub.. If you can find both options for your car.. I like number two VS extended lugs. Make sure you get centric ones too as both of those options above do look to be..
good luck!
Old Aug 2, 2013 | 12:10 PM
5fanatic's Avatar
My Ride: 2007 BMW 550i
I have a 2007 550 with 20mm spacers on the rear. I'm using H&R spacers with extended lugs. Got them from turner motor sports. It's been almost 2 years now and no issues.
Old Aug 3, 2013 | 06:04 AM
Dishoom's Avatar
My Ride: 2008 BMW 550i Sport
Engine: N62
I've had Type 1 on my car for nearly 2 years without issue. However, I am concerned that whenever I go have my tires rotated, the tire tech might mix up the extended length with the regular ones used on the front. I think I'm going to mark them with a silver paint pen to easily tell them apart.
Nihilation
Jul 10, 2022 11:32 AM
G530
May 15, 2015 10:42 AM
BurtonSnol3order
May 7, 2015 08:35 PM
KLR4LIFE
Apr 1, 2015 10:38 AM
lowcg3
Mar 26, 2015 11:23 PM
