Which wheel should I go with? Help
So I've been looking around at wheels for my 08 550i. Has the original 19" wheels. I wanna keep the same diameter to use the same tires. The reason I wanna switch wheels is because the OEM are a pain to clean. Too many tight spots.
These are the wheels I've got my eyes on.
TSW Strip 20mm offset front/rear 19x8/19x9.5
TSW Zolder same specs as the strip wheels
and last but not least
VMR V713 19x8.5/19x9.5 20/22mm offset.
My only concern with the VMR wheel is that its .5" wider. Im wondering how my 245/35 front is gonna look on it. I dont want the edge of the wheel to be wider than the tire.
What do you guys think?
My Ride: 2004 E61 530D - Dynamic Drive - Active Front Steering Sport Seats - Voice Control - Head Up Display - Nav Pro - Bluetooth - Panoramic roof - Front/rear heated seats
The plan is to remove the OEM wheels because the clear coat (if it had any) has come off. The wheels are badly stained and has some mild road rash.
I wanted to remove them and put some aftermarket while the OEM get completely repaired. Once the OEM are done put them away. If I ever feel the need to put them back, Ill be able to. If I sell the car or whatever the case may be.
madein
Jun 6, 2015 11:48 AM
Virak1985
Jun 2, 2015 11:16 PM
