What's the secret to installing a new pedal set on the brake pedal
So I've got my dead pedal and my throttle pedal installed, no problem.
But this damned brake pedal is KILLING me.
what's the secret?
How do I best drill through this metal? Any tips?
Thanks,
Jed
what's the secret?
Thanks,
Jed
My Ride: 2011 E92 335i M-Sport 6MT
The secret is a sharp drill tap (the tool that places a divot on the metal after a sharp tap from a hammer) after you've marked where you want to drill. Then of course, make sure you have SHARP drill bits. And NEVER use your body weight to push the drill bit into the metal as the drill is turning. TAKE YOUR TIME. Let the drill bit do its job in scoring away at the metal. ![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
As an aside, I was told that it took Dinan close to 30 minutes to tap and drill the holes on the brake pedal b/c the installer claimed that the metal "was a bitch" to drill through!
![Crying](https://5series.net/forums/images/smilies/imported/crying.gif)
One tip is cover your ear. The space under footwell is small, and high pitch noise from drilling might be bad for your ear.
The last tip is you need at least two drill bits
Awest91
09-17-2022 11:05 PM
pcy
09-12-2021 06:55 PM
TexaZ3
05-06-2015 09:54 AM
BrandonSS
03-13-2015 12:19 PM
