What are you guys using for iPod/iPhone integration?
Hi, those of you with iDrive, what are you using for your iPhone/iPod integration?
I've got a 3G iPhone that I want to charge and access music off via the iDrive system. I'm guessing the best solution is something like the BMW iPod module plus a sync.doc for the ashtray?
Let me know what you are using or recommend.
My Ride: 2010 VW Passat Wagon 2.0l Tsi
Grey/Grey Budapest 18"
Lost to HPFP issues:
08 535i sport pkg
Lost to Dreaded E61 Sun roof leaks:
07 E61 530Xi
The one that came with the car... in the arm rest....
Originally Posted by GENEaTALS' post='662245' date='Sep 4 2008, 09:37 PM
to clarify, you have a 2006 M5 correct? Does your car already have a USB plug?
Tell me more about the USB option... what year was that introduced? Can it be retrofit to earlier cars? How does it work?
I understand there is also the Dension Gateway 500 which has a number of connectivity and UI benefits vs. the BMW ipod interface.
Can someone briefly describe or point me to pics of the UI benefits of the Dension vs. the BWM unit?
Thanks!
Thanks!
I didn't think you could use the ipod interface and the armrest cradle at the same time. If you used the ipod interface it would charge your phone too but then you can't put it into the cradle for the aerial. the iphone doesn't have an external aerial socket so the benefit you are getting from the cradle is questionable anyway.
I think the Dension may be the only solution for now that might charge an iPhone 3G since they changed the charging scheme on the 3G from previous iPods and as a result made all previous cables/adapters obsolete. AFAIK, the Dension cable is available (or will be shortly) that will charge a 3G iphone.
Here's a pic of the dock...
Originally Posted by VirtualRain' post='662740' date='Sep 5 2008, 11:00 AM
Yeah, that's my understanding as well... I'm not interested in the BMW cradle. I'm thinking of buying the sync.dock from www.2point5.com (ashtray dock) and hooking that in through either a Dension Gateway or a BMW iPod adapter.
shervinj
04-23-2015 05:42 AM
