A way to slightly lower 535xi and save money on bump stops
Old Aug 11, 2022 | 01:38 PM
colriem's Avatar
My Ride: E61 535xi 6MT
Engine: N54
Default A way to slightly lower 535xi and save money on bump stops
E60 strut mounts (i/xi) (31306775098) are interestingly the same strut mounts that are used on the RWD E9X vehicles. It is somewhat well known that RWD E9X owners will swap the E9X xi strut mounts (31336775097) for slight lowering (12mm drop). Also, the E9X xi strut mounts have a more rigid design with support ribs added. I tried this out and am pleased to say that the E9X xi strut mounts fit perfectly in the 535xi, which is great for a slightly lowered ride height! This would also work on the RWD E6X vehicles, however, they have better lowering options than us xi guys.
Also to note, the E6X xi strut bump stop (31306774699) only has the Genuine OEM option available ($34.29 a piece). I instead used the E9X xi bump stop (31336777636) from Febi Bilstein ($9.99 a piece). They are identical in dimensions except the E9X bump stop has a slightly tighter inner diameter, but fits on the 535xi strut with no problem!
Old Sep 29, 2022 | 09:04 AM
AtlasE61TT's Avatar
My Ride: 09 535i xdrive, PP,WP,LCI
Model Year: 2009
Engine: N54
Can you post the links to where you purchased the parts you swapped out, definitely interested in this solution.
Old Oct 31, 2022 | 08:50 AM
neilv's Avatar
My Ride: E61 530xi 6MT
Engine: N52
I was looking into doing this a few years back before I stumbled across some H&R springs at the local pick n pull yard.
31306785962 is the front mounts you want, they are the LCI versions with normal length studs (31336775097 is for pre-lci x drive and have longer studs to accommodate a spacer on the pre-lci versions) other than that they are the same part. They will lower ~8mm over the 098 mounts (E90 sport suspension & E60 x-drive production until Sept 2008) and ~12mm over the 31336760943 mounts (E90 non-sport suspension, E60 x drive production oct 2008+ & rwd E60)
Old Dec 6, 2022 | 05:52 AM
kysteez's Avatar
My Ride: 2008 535xi
Engine: N54
Clever idea. Just order the 962's. I will report back the amount of drop I get out of them when I install struts this week.
rayray1558
May 9, 2017 04:58 PM
Brant535
Jun 11, 2011 04:32 PM
providenceleaf
Jun 30, 2009 06:04 AM
SP530xi
Apr 19, 2006 09:31 AM
arc1
Jul 11, 2005 08:40 AM
