Want cheap mod? Replace the spark plugs!
Old Feb 4, 2009 | 06:50 AM
  #51
5_Is_Alive's Avatar
My Ride: My 5 and I met on Father's Day 2008 and have been together ever since. 20" Wheels (Make TBD), premium package, sport package, AiB V3 upgrade and a Passport Escort 8500 Radar Detector.
Originally Posted by heavy_g' post='784854' date='Feb 4 2009, 07:40 AM
Thanks! I had to find out the hard way.
Oooh, not liking the sound of that... everything work out ok with that?
Old Feb 4, 2009 | 07:20 AM
  #52
halston@bsw's Avatar
You could run copper plugs over the factory '100k platinum iradium unobtanium'... Will result in better overall performance as copper is an AWESOME conductor of electricity. They will require more maintenance as you have to change them much more frequently.
I use copper on both my M3 track car and my street car. Both of which came from the factory with the OEM BMW Bosch +4 Platinum. Both run BETTER on the copper.
Old Feb 5, 2009 | 05:29 AM
  #53
heavy_g's Avatar
My Ride: '05 545i
yea. but it took me an hour of pulling and pushing the plug in an out to figure out i need to untighten power cable.
I WILL NOT REPLACE MY OWN SPARK PLUGS AGAIN.
Old Feb 5, 2009 | 05:31 AM
  #54
heavy_g's Avatar
My Ride: '05 545i
I got the NGK Iridium's. very happy with their performance. The car feels much smoother now, especially at slow speeds as well as starts and stops.
Old Feb 5, 2009 | 08:19 AM
  #55
The e36 M3 doesn't seem to like those. All of my vehicles run on copper. Works great
Old Feb 5, 2009 | 09:29 AM
  #56
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
Originally Posted by mhs525' post='782758' date='Feb 1 2009, 07:08 PM
You have to remove the nut that holds the main power cable to the fire wall. Then you can move the cable enough to give you the space you need to get the coil out.
Good luck
It's made of plastic. Use two 3 inch 3/8 drive extensions instead of a longer ext. Much easier to pull
the plug out. Now that I know the trick, next one will be quick and easy( and no bruised knuckles).
Old Feb 16, 2009 | 05:19 PM
  #57
#1bmwlover's Avatar
My Ride: 545i Black exterior with balck interior. Sport package. K&N air filter.
Thumbs up
OK guys. I'm confused with all the spark plug types. I know that it's personal prefrence, but I'm about to hit the 50k soon. I'd like to change my spark plugs, but I have know idea what to get. I want something that gives HP, but at the same time, I don't want my car to be a gas sucker. Need something in the middle so to speak.
Also, what about Spark Plug "PLATINUM+4" Bosch and Spark Plug "PLATINUM Ir FUSION+4" Bosch ?
Old Feb 16, 2009 | 08:47 PM
  #58
525iEnjoy's Avatar
post #42 for NGK numbers
Old Feb 24, 2009 | 07:30 PM
  #59
#1bmwlover's Avatar
Alright. I will go for NGK iridium Thanks 525iEnjoy!!
Old Feb 25, 2009 | 08:59 AM
  #60
525iEnjoy's Avatar
No Problem, Thats what I went with also! now I have to install them
socale39
Sep 5, 2023 08:30 AM
gergnang
Feb 2, 2021 07:29 AM
chadillac2000
42
Sep 13, 2017 11:15 AM
ETNav382
Apr 24, 2015 07:29 PM
BrandonSS
Mar 30, 2015 09:48 AM
