Unlucky?
My Ride: E60 530d MSport Auto, 19" 172 Spiders on ContiSports 2's, Pro Nav, Adaptive Xenons, Bruce M's V6 Rear LCI Cables/Lights, Number plate LED
I've had the E60 530D MSport since late 2009 after selling on E92 325D Msport.
Since then, this is all the work I have had carried out and all at main BMW stealerships:
[1] Turbo and Cat went. One Sunday when I was up in Bradford. RAC towed it into JCT600 and several weeks later ~£2,700 for a new turbo and cat! The cat had sucked oil from the turbo!
[2] Transmission Failure. She went into safe mode. Diagnosed as oil leak by Stratstone Harrogate. New pan fitted and oil on a "lifetime sealed" unit replaced. Cost ~£800. Funny thing is this stealership could not fix the car properly and after taking my £ told me the car was still in safe mode and possibly needed a new metronics unit or even a new gearbox. They let me drive the car back to the midlands as I wanted a second opinion. Driving a car in safe mode for that length of time was very scary and in retrospect I would never do this again. I took it to a local stealership and they told me Stratstone had not plugged in a connector properly! As you can imagine I was not a happy bunny! Local stealership were very helpful, internally billed Stratstone to fix the work.
[3] Light Module failure. Replaced and reprogrammed ~£600
[4] Suspension. Had front control arms and rear joints changed ~£800
[5] Exhaust manifold. Got the dreaded diesel fumes in the car. Diagnosed as cracked EM. Sytner had pleasure in charging me ~£900 for the change.
[6] Inlet manifold. With all the stories on swirl flap issues, I thought with all the luck on my car I should have the revised inlet manifold fitted. I did think about having the car de-flapped. But I have seen potential issues with this. So at least there is a 2 year parts and labour warranty with BMW. I had this done at the same time as the EM. Left the stealership ~£800 lighter.
Anyone else had as much luck with their E60? Shes got around 130,000 on the clock now so she's been round the block a few times. But been told that she's should be able to go around the block a few more times yet!
Also, has anyone ever had any joy with goodwill from BMW? Because they just did not want to know with any of my issues!
Percy
![Fcuk](https://5series.net/forums/images/smilies/imported/fcuk.gif)
![Angry](https://5series.net/forums/images/smilies/imported/angry.gif)
Percy
I don't think the miles (kms) are all that high but it's possible the previous owner was neglectful about regular maintenance or abused the car in other ways. I don't think BMW or any car manufacturer can be expected to pay for or correct harm done to a car under those circumstances.
If you feel you can prove manufacturer's defect you might have a case. But bent suspension parts, cracked manifolds not likely - the swirl flaps and electronics might be another case ... ... automatic transmissions and lifetime anything - UGH - another BMW misery
![Wacko](https://5series.net/forums/images/smilies/imported/wacko.gif)
