Ultimate Eyebrow Upgrade
#171
My Ride: F10 535I
Model Year: 2016
Originally Posted by brabusw209amg' post='761873' date='Jan 7 2009, 02:25 PM
oh yeah. we had to use almost all ur glue cuz I had to fill in holes the size of NYC potholes with it. LOL.
Just kidding....
#172
Here is what I am looking at...
I scratched that area with my nail and it almost definitely feels like plastic...
#173
My Ride: F10 535I
Model Year: 2016
The part in the pix is plastic.... you gotta go underneath
#174
Originally Posted by Eugene134' post='761878' date='Jan 7 2009, 08:28 PM
You gotta take that plastic piece off. Its on with clips. real simple to do..
#175
My Ride: F10 535I
Model Year: 2016
Originally Posted by tonymac' post='761884' date='Jan 7 2009, 02:35 PM
Oh ok... Silly me... I will try tonight... No, wait, I am too tired... Tomorrow will work!
sounds good... Good luck.
#176
Nice Job Eugene this proves that everything is possible. Btw you sure have guts to cut your headlights like that for that i give you 80+.
#177
Hahaha... It is nerve wrecking... But I am not going to do it yet... I am just getting all the info I can so that when I get the LED's I am prepared... We will see...
#178
My Ride: F10 535I
Model Year: 2016
#180
Oh yea. This is major. If you finish cutting it, make sure you vacuum the shavings and clean the area good before you pull the circuit out. Tilt the unit where the headlight is aiming up. That way the shavings and rubber doesn't fall through the holes and end up in the eyebrow.
Also remember the position of the LEDs are facing. The new LEDs need to go back in exact. That's if you do not have a tester. If you have a tester, place the LEDs in, test, then solder.
Its not that hard. You have nothing to worry about. The circuit board is stronger and not as fragile as I thought. I hacked away at the plastic, pulled and yanked the board, desolder and each step, I thought my circuit board was f*cked. The real test was when I used the power supply that John borrowed from Eugene. We put the LEDs in, turned it on and nothing. I was like, "figures". But turns out the LEDs were reversed.
So the circuit board is pretty tough. BUT, doesn't mean go crazy with it. Do it right and be careful. There are still risk.
