tire pressure
Originally Posted by dropped545' post='825323' date='Mar 24 2009, 08:24 AM
Originally Posted by nigxdoof' post='825331' date='Mar 24 2009, 08:49 AM
On my 20's, I run around 42psi. That's with 245/35/20 and 285/30/20. (Falken 452's)
- BMW or aftermarket rims?
- What diameter wheel and
- What profile tire are you running?
You must be pounding through some mighty big potholes?
Originally Posted by dropped545' post='825335' date='Mar 24 2009, 08:53 AM
u planning on selling your 20s anytime soon im looking for a set.and are they brushed alm with a crome lip....???if youn are selling let me know b4 this money burns a whole in my pocket.....lol
![Happy](https://5series.net/forums/images/smilies/imported/happy.gif)
Originally Posted by luigi524td' post='825339' date='Mar 24 2009, 08:56 AM
Your car's recommended tire pressures are noted on the door jamb. 3 questions:
I also put 40lbs in my stock, 19's. In NYC, it's a must. I'd much rather have a tire blow than crack a wheel, which by the way, I've already done, thanks to putting 40 lbs in my tires. The tire sidewall on one of my 19's last year blew out, but the wheel was perfect. It was the loudest thud ever too. I was convinced my wheel was broken. The wheel place told me the increased pressure saved the wheel.
Originally Posted by C's Bimmer' post='825354' date='Mar 24 2009, 09:09 AM
I also put 40lbs in my stock, 19's. In NYC, it's a must. I'd much rather have a tire blow than crack a wheel, which by the way, I've already done, thanks to putting 40 lbs in my tires. The tire sidewall on one of my 19's last year blew out, but the wheel was perfect. It was the loudest thud ever too. I was convinced my wheel was broken. The wheel place told me the increased pressure saved the wheel. ![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
Originally Posted by luigi524td' post='825360' date='Mar 24 2009, 09:20 AM
Like C said - with that low a profile I'd run the "full load" recommended tire pressures. The ride will be harsh. From the BMW Manual for the 19" set up and full load see the bottom right side of the chart - that suggests up to 45lbs psi for the rear!:
