Tire fitment question
My Ride: 2006 BMW 550i "Ben Hogan's 5 Iron"
SilverGrey/Black Sport, L7, NAV, CW, AS, Split FR
2003 Audi A4 3.0 CVT "Part of the Moniker"
Silver/Ebony, Prem, CW, Star 17s
Will 167 OEMs with m6 tires fit a non M e60?
Why I ask? It seems some say spacers are need for the front on the e60 to flush the edge. So it would seem there is enough room for the front 255s. For the rears there might be a problem because of the larger 17 et offset. Curious because I've read posters noting that the 166 oem with m5 rubber (285 width I think) doesn't rub on the rear.
I'd like to run wider rubber if possible. I've seen pics of the m6 offsets with 245 fronts and 275 rears in 167 or 166 styles and the look isn't aggressive enough. Like the wheels are flushed to edge but the rubber looks too narrow. The rear stance is the most notable.
I read about rolling fenders but this seems to be a last resort.
Any thoughts?
Btw. Simplfying my question. Anyone put on 167 wheels straight from a m6?
Thanks.
Any thoughts?
Thanks.
That said, isn't it the width that causes the rubbing, as there is considerable height clearance? Or do I have this backward?
Sorry for the dumb questions. But when you hear people saying only the fronts m5 166s will rub, you start to think, hey wait. Of course you couldn't mix two different profiles.
My Ride: Bmw 530d 2004
Thanks for the insight. I had forget about the higher profile and the higher profile is noticeable now that you mention it.
The M5 rears would probably rub too. The rear fenders in M5 are the same as in non-M5, except that they are rolled by manufacturer already.
My Ride: 535d
Model Year: E61 2006
M5 use a bigger profile tire and will rub. See this topic and you will know everything about the correct tire size for the E60: How to choose the tire size?
True M6 wheels don't need spacers.
+1 no spacers are needed for OEM 167s. recommended tire sizes for a non-M e60 with those wheels and what we'd advise to stick to are 245/35/19 and 275/30/19.
Nerweezzy, what spacers would you recmommend for 124s?
- 5mm front
- 12-15mm rear
Make sure they're hubcentric (rear ones). The 5mm spacer is so thin that the original lip of a wheel hub will stick through the spacer and center the wheel.
- Antti -
carid
04-29-2015 04:20 AM
