Sunday Funday 545i Wheel Plastidipping
Plastidippin the wheels as we speak!
I'll keep updating as it goes on. Taped the insides with newspaper (2nd and 3rd pics) and also around the rim (1st pic).
My Ride: '04 530. Black on Black
Black Grills
Tint
Ipod Retrofit June '10
I did this a few weeks ago. So far no problem at all. I will need to do some touch ups in the spring, the hub near the bolts was very difficult to get good coverage. I also did the inside of the wheels, as you could still see the silver when the wheels where on.
1st coat of 3 coats. And youtube link for technique (not that theres much to it
Just put on the second coat after the first one dried. it starts to look a lot better after the second coat. The key is being patient, not applying it too thick at one time.
Jay8s, how does it hold up in washes? (Touchless)
Black Grills
Tint
Pressure washing directly on them is not a good idea. I have had my shadow line plasti dipped for over a year with no problem in the local touch less washes. I went its 4 coats front, 3 on the back. The problem is when you have an edge that is not in contact with the wheel. It will start peeling from there. I have some pics somewhere, and will post them later, currently out and about.
Black Grills
Tint
Also a good idea to stuff some cotton balls in the lug holes, so the dip does not peel when you put the bolts back in. It leaves some silver, but the lugs will cover that.
