sub and amp
Old Jan 28, 2011 | 02:25 PM
tran23's Avatar
My Ride: 04 530i Jet Black Blue Halos 10000K HIDs Blacked Out Tail Lights Matte Black Grill
Where do i put the ground for the amp and is there any pics i can see?
and for the power should i just undo the nut and put it right on there or somewhere else?
Old Jan 28, 2011 | 04:39 PM
inktoxicated's Avatar
My Ride: 2006 530i mystic blue
i used the batterys stock ground. theres a stud near the tailight. take off the battery panel and ull see where the negative wires goes to the chasis. as for the power u can mount it directly to the batt or the fuse block theres a spot on the fuse block u can run up to a 4 g wire terminal at. thats where i had mine but switched to zero gauge and had to run it off the battery. gets kinda tight back there
Old Jan 28, 2011 | 08:57 PM
tran23's Avatar
alright thanks. i didnt even think of putting it in the fuse box
Kaane
Mar 15, 2022 05:16 AM
skrelnik
Sep 18, 2015 07:24 AM
spykes
Jul 10, 2015 07:49 AM
ferrary01
Jul 9, 2015 12:38 PM
lukieno1
Jul 1, 2015 04:37 PM
