Sound System?
Old 06-22-2007, 05:58 PM
alpinewhite's Avatar
My Ride: No mods
im not an audiophile. I just need extra bass than what the L7 provides. Trust me, the JL sub provides enough bass. It can drown out my exhaust, which is pretty loud at low rpms. Im running a mono channel amp at 500w btw.
Old 06-22-2007, 06:37 PM
rjcastr's Avatar
you have any opening sin the car?
Old 06-24-2007, 11:19 AM
NY550i's Avatar
My Ride: Fully Loaded Monaco Blue 550i Sport
500w is enough for you? im pushing about 700-800 RMS and theres barely any bass.
Do you any cutouts?
These cars don't come with a ski pass like the old winter package 5 series did?
Im thinking i need some 2 12" JL W7s with a JL 1000.1 amp... that should get the job done for that sealed trunk.
Old 06-25-2007, 03:38 PM
My Ride: No mods
Do you any cutouts?
depends on your taste. 2 JL sub is overkill. I love bass, but I dont want it to drown out the music.
btw, i have no ski pass
heres my set up. i think this clip is pretty gangster .
ported sub
Old 06-25-2007, 03:40 PM
xexyus's Avatar
My Ride: 05 530 Titanium Silver/Sexy black
Do you any cutouts?
Your probably going to need a 1000.1 to each sub. You do that and im sure you can pass some bass through that bulletproof trunk of ours
Old 06-26-2007, 11:35 AM
NY550i's Avatar
Yeah your right i will need one for each sub... i think i'll just do one w7 12" and 1000.1
Old 06-28-2007, 01:46 PM
sideeffects's Avatar
I have 2 JL w6v2's running from a 1000 to 1 and the bass definantly makes its way WAY through the trunk.... I don't know if you are planning on replacing all the component speakers? But I have mine running through a JL cleansweep and JL cleansweep "signal summing interface" and with the additional audio control (being able to turn the bass volume up and component volume down and vice versa) and volume control I can really get the car to bump... but anyways thats alot of equipment if you are just tryen to get some subs hooked up lol... P.S. w7's are not as clean as w6's I had w7's my friend had an escalade and had them swapped out for w6's... he said the w7's were just too sloppy sounding not as crisp and I definantly agreed with him... hope this helps...
Old 06-28-2007, 02:23 PM
Kellywb's Avatar
RJ,
How come you did not go IB? I am on my 4th box and 6th different sub in the trunk. I am having a custom box built from Brich than is a parallagram against rear seats for 2 USD 10" driven by a Zapco 500.1. It will only be 8" deep. It is the best SQ with good output that I have tested. No ski pass. Did remove rear deck 4". Don't use rear fill and it helped a little to remove but plenty of bass enters the cabin.
We still need to hook-up so I can look at the doors. I was waiting for the H650 before I re-place the cabin speakers but now I think I might wait for the JBL MS-8. We'll see.
Kelly
Old 06-28-2007, 10:52 PM
FANTASTIC 5's Avatar
Originally Posted by NY550i' post='438363
i had one 12" MTX 8500 sub in a sealed box and it was pretty loud. But then I sold it and got a 12" JL Audio W6v2 in a ported box and im in love with my sub now. Contact member FANTASTIC_5 for quotes for audio stuff (he owns a audio shop).
Thanks John. Your sub does sound pretty sweet. Really good output and amazing sound quality for being in a ported box. For "sq" W6v2's are the way to go.
Old 06-29-2007, 04:47 PM
NY550i's Avatar
Originally Posted by FANTASTIC 5' post='441261' date='Jun 29 2007, 02:52 AM
You're definitely right about e60 trunks being sealed. But there's other ways to get bass into the cabin WITHOUT cutting out the ski pass or any cutting for that matter.
There are countless reasons why your set-up may sound like poop. Did you install everything yourself? Off the top of my head, here's a few possible reasons:
- your subs are improperly wired (ie. series/parallel)
- your subs' impedance don't match your amp's
- your subs are in a pre-fab box (improper airspace)
- your amp's gain isn't properly set (http://forum.realmofexcursion.com/showthread.php?t=1990)
- your line-out converter's gain isn't properly set
- your amp's subsonic filter isn't properly set
- your amp's lp filter is crossed over at the wrong frequency (or maybe it's on full-range)
- you're using too much bass boost
- your subs are firing in the wrong direction (usually rear-firing in trunks)
Is your box ported or sealed? If you like a lot of bass, usually ported is the way to go. But you shouldn't throw the sub in any oridinary box (ie. universal "prefab"). Every subwoofer is different; they have different t/s parameters and different airspace requirements. For example, subwoofer "A" may require 1.3 cu. ft. of airspace for a sealed box, while subwoofer "B" will only require .8 cu. ft. for optimum sound.
Let me know if you're interested in any car audio gear, I stock most of the JL subs and give forum members really good deals.
I think everything was done right but then again you never know... i did go to get the subs and amp installed at a very well known shop that seems to have some proffesional installers there... the installers even drive matching E38 740s LOL
Its the mtx 4500 2 12" subs in a sledge hammer box that came from MTX with a 850 watt audio planet... i think its just not putting out enough power to get the bass thru the cabin.
I was thinking of maybe purchasing some different subwoofers and keep the amp and see if that helps or i might just purchase something more powerfull and this time get a ported box...
Any sub+amp combo you recommend?
Quick Reply: Sound System?
